How to add hazard lights and high beam flash to pass function to your 06-12 R6 : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > How To's...
Old 10-29-2012, 07:48 PM   #1
vp6799
I wanted to add the hazard lights and flash to pass function to my 08 R6R, but there was no way of doing it easily.
Thanks to Marco77 for telling me about the European model R6R that comes with those exact options.
The install went easily. The only mod that needs to be done, is to pull one pin from plug and tap that wire into another in that same plug.
Here's a quick write up about the install:
Tools needed:
Wire strippers
Wire cutters
Pick
Heat shrink
Soldering gun
60/40 solder
Zip tie
First thing was to grab a left side control for the European 08 R6R from eBay.
1: When I received it, everything matched up to the U.S. version except one wire. Which happens to be the flash to pass wire. (Sorry, I don't have a picture of the harness before the mod.). This is what it looks like:
2: Pull back on the rubber wire covering enough to allow you to cut and solder the wire without having any restrictions. Put a zip tie around the end of the sleeve tightly to hold it in place. This is assuming you want a factory look when complete. If you don't care about the look since its covered by plastic, then just cut the rubber sleeve back some.
3: Look at the top of the plug and you'll see 5 wires. The top is the side that has the release button.
From left to right, the wire colors are:
Green
yellow
white w/ yellow stripe
brown w/white stripe
red w/ yellow stripe
4: you will need to pull out the white w/ yellow stripe wire from the plug. To do this, Look at the face of the plug (the part that fits inside the other half) and you'll see all of the pins. Use a pick to move the locking tab away from the pin. Once the tab is away from the pin, pull the wire and pin out from the other end.
5: Now that you have the white w/ yellow stripe wire removed, cut the pin off and strip some of the rubber exposing the wire inside.
6: Now grab the yellow wire. You need to strip a small section of rubber from it to allow you to solder on the wire that you just cut. There's no need to cut the wire off, just use a pair of nice wire strippers or a razor blade to slice a small piece of rubber coating off. You only need about a 3/8" or 1/2" size of stripped wire to work with.
7: Now take the white w/ yellow stripe wire and feed it in through the yellow wire that you just stripped to get a good connection there.
8: Grab your soldering gun and 60/40 solder and solder the wire connection that you just made.
9: Now that you have that soldered, you gotta wrap it up to protect it and to keep it from shorting out in case it touches any metal. Look at the plug to see where the yellow wire is located in it. Pull that pin out of the plug the same way you did the other one.
10: With the pin removed, you now have a way to slide some heat shrink over the soldered joint. Slide the heat shrink on and heat it up well enough to shrink it completely. It burns easily, so don't sit there with torch on it. A basic lighter, grill lighter, or mini torch, will work just fine.
11: Now you can put the yellow wire back in the same spot that it came out of in the plug. (In case you forgot, it goes in on the side of the green wire.)
12: If you pulled back on the wire covering and zip tied it to hold it in place, you can now cut the zip tie and pull the covering back in place. If you cut the covering instead of pulling it back, skip this step.
13: Plug the control harness into the bikes harness and test out the function.
The hazard lights are plug-n-play. You don't need to do anything to it.
Now you should have hazard lights and flash to pass function on top of the rest of the normal controls.
Here's some pics of the finished harness:
The empty hole in the middle is where the white w/yellow stripe wire is located.
Close up shot of the connection point:
Finished harness. Looks like it came that way:
A cheap video to show the high beam function:
vp6799 is offline   Reply With Quote
Old 11-08-2012, 12:27 PM   #2
Marco77
Ride Safely
Marco77's Avatar
Bike: 2008 YZF R6
Re: How to add hazard lights and high beam flash to pass function to your 06-12 R6
Just saw this today, nice write up man
Marco77 is offline   Reply With Quote
Old 11-08-2012, 05:26 PM   #3
motoman21
motoman21's Avatar
Bike: '12 R6
No vid of the flashers in action? Nice work though.
Soon to be seen...unveiling in march!!!!
motoman21 is offline   Reply With Quote
Old 11-10-2012, 11:00 AM   #4
TinyDancer
...in my hand
TinyDancer's Avatar
Bike: '12 R6
really cool idea...part # for those interested is 13S-83969-00 for the euro switch.
-Alex
"Ride, eat, sleep...repeat"
TinyDancer is offline   Reply With Quote
Old 11-10-2012, 11:00 AM   #5
TinyDancer
...in my hand
TinyDancer's Avatar
Bike: '12 R6
-Alex
Old 11-20-2012, 08:15 PM   #6
vp6799
Thanks, it was an easy mod. I'll have to grab a vid of the flashers when I get back from the vacation.
Old 11-21-2012, 08:23 AM   #7
verybigtiter6
verybigtiter6's Avatar
Bike: 2009 r6, 2012 cbr 250
you said " The hazard lights are plug-n-play. You don't need to do anything to it. "
where does the hazard light plug into?
verybigtiter6 is online now   Reply With Quote
Old 11-21-2012, 08:38 AM   #8
Marco77
Ride Safely
Marco77's Avatar
Bike: 2008 YZF R6
You unplug the light switch control from the harness take off the old one......mount the new one and plug it inn to the harness that's all you have to do...but if you want to use the flash to pass button the you need to do a little mod which is explained in this thread.
Old 11-21-2012, 08:44 AM   #9
bryan j
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Nice write up
But what's a flash to pass function?
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
bryan j is offline   Reply With Quote
Old 11-21-2012, 08:53 AM   #10
Marco77
Ride Safely
Marco77's Avatar
Bike: 2008 YZF R6
Originally Posted by bryan j View Post
Nice write up
Think of the light switch in your car when you pull it against you it triggers the high beam.....samething in the bike
LED Strobe Hazard Lights ShadowBlade72 Appearance and Exterior Mods 6 06-04-2012 04:05 AM
How come we dont have hazard lights? R6Hed General Discussions 27 06-25-2009 12:28 AM
Hazard Lights? adamp General Discussions 8 07-27-2007 02:53 PM
Hazard Lights on the 06? massRaven Appearance and Exterior Mods 17 12-10-2006 09:26 AM
Hazard lights? Elemeno Safety Equipment 8 03-18-2005 01:19 PM
