» Site Navigation
» Motorcycle Forums
10-30-2012, 06:32 AM
#1
Bike: 2008 Yamaha YZF-R6
SOme basic questions about braided brake lines
Currently looking to purchase a set of braided break lines but I'm yet knowledgeable on the topic.
Link below to the brake lines I'm currently eyeing off (though I may well go for red banjos):
Link to the manufactures website below.
http://www.coremoto.com/product_p/fr79.htm
Atm I'm confused why anybody would want extra length in their brake lines. Is there any good reason to request the length to be longer than stock?
Also looking att the picture below you can see that various routeing configurations are available:
Is there a general conciseness on here which option is best?
Thanks and sorry for all the basic questions.
Mick.
10-30-2012, 06:44 AM
#2
pin it to win it
Bike: 07 r6, 06 yz250f
Get the fren tubos from agg. Fine of the best lines available.
different length would be for ppl with stretched swingarms or lowered forks
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
10-30-2012, 07:12 AM
#3
Speedy Claxton
Bike: '07 R6
Re: SOme basic questions about braided brake lines
What he said ^^
Hit up aggracing for your lines, and that routing option outlined is the one you will use.
10-30-2012, 07:15 AM
#4
scared of big tracks
Bike: 07 track slut
Originally Posted by
bryan j
aleithauser
What he said ^^
Have personally used the Fren Tubo's on all my bikes and will be getting one for a buddies bike as well.
10-30-2012, 07:41 AM
#5
Recreational Stuntrider
Bike: 03 R6 Stuntbike
I get mine cut a the drag racing shop down the street. Tried and tested on the strip.
As for length, it's just more fluid in your shit. Also, if you want to adjust suspension you'll have slack.
As for routing, it's all preference.
If your just doing street riding, SS line are meaning less.
Finally, please support our local forum vendors (Agg Racing).
R6_350z
not putting miles on your bike because you want to keep it new is like not having sex with your wife because your saving her for the next guy
10-30-2012, 08:07 AM
#6
Why yes I don't!!!!!!!!!!
Bike: Starts w/ R ends with 6
well you might want them longer if you do lots of wheelies. I prefer the superbike type threaded connectors at the caliper and single banjo at the master.
10-30-2012, 10:35 AM
#7
That pretty much clears things up thank you
I'll look into agg racing before making any purchases
10-30-2012, 11:03 AM
#8
Bike: '12 R6
I think agg is sold out from the last time I checked the site.
Soon to be seen...unveiling in march!!!!
10-30-2012, 01:14 PM
#9
Two Bro's=ORGASM *nohomo*
Bike: 07 R1
xzpolskix
The Fren Tubo's are out of control! I put the Type 4 CF lines on my bike (with vesrah RJL pads too) and OMFG the brakes are scary! I went to braking only with my index finger and that helps.
-Jamie M.
07 R1 -
Flash tune 'd,
A&R Race Baffles with Akrapovic Y Pipe (
wrapped in DEI Titanium header wrap ),
Renthal MX Kevlar Grips, HVMP Extra Heavy Weight bar ends, Saddlemen "Tech" seat (memory foam + gel), Skeen Racing Extended White frame sliders, Shermoto Levers, Proton flush mount front signals , BMC race filter,
Elka Stage 4 adjustable shock ,
iPod 4th Gen with Harry's Lap Timer Pro with Emprum UltiMate 5hz GPS and Ram mount, 190/55
Bridgestone S20 's,
Garmin 2595LM GPS in RAM stem mount,
MikeyMoto Ultralight rear rotor , Ultra
high power LED running lights , trimmed
ebay fender eliminator , Shorai LFX14A4-BS12 ultralight battery, Fren Tubo Type 4 CF lines (front and rear), Vesrah RJL front pads, Ferodo Sinter Grip ST rear pads, Amsoil MCF full synthetic oil, Amsoil EA15K13 car oil filter, Wurth HHS2000 chain lube, Shell 91 octane NO ETHANOL fuel ONLY.
Coming soon: Race Tech fork kit, EK MVXZ 520 chain, Drive Systems USA Superlite Steel rear sprocket (+2/47t), Driven drilled steel front sprocket (-1/16t), will try to reach top speed of 305kph/190mph.
10-30-2012, 02:27 PM
#10
motoman21
if for some reason he cant seem to get them also check with chiefsmokedawg aka bauce racing
Linear Mode
HTML code is On
