» Site Navigation
» Motorcycle Forums
11-02-2012, 12:39 PM
#1
Bike: 06 YZF R6
Almost cutting out
I noticed that when my bike isnt warmed up and the throttle is so much as touched it dies..That has never happened before. Also when I am riding and I come up to a stop the RPMs go very low to the point where it almost dies but doesnt and then returns to normal.
I changed my airfilter, plugs and added smog block offs. I do have PC3 but while Iw as away the bike was taken in to the mechanic and from looking at the repair order it says he "took map out of PC since no exhaust installed."
I did a search sorry in advance. Could it be that since he took the map out it kind of screwed with the system?
U.S. Army Infantry (101st)
-2006 R6 Raven
6000K HID Projectors w/
Blue Angel/
Red Demon eyes, Diablo Corsa Rosso tires, PUIG DBble Screen, ASV black shorty levers, Pro Grips, GYTR Air Filter, Int. Taillight, Rear Solo seat cowl, 520 Kit, Ttuner mid pipe, Leo Vince "Italia" SO, PC3, Agg Racing Smog BlockOffs, Auctmarts Race Replica Fairings.
-1978 Trans Am
Chesterfield Brown , All original rebuilt 403 w/ th350 Trans, Hooker long tube headers, 2.5" X-pipe exhaust, .030 bored, Comp Cams Rocker lifter kit, BFG Radials 245s, K&N Air filter.
11-02-2012, 12:48 PM
#2
Re: Almost cutting out
I have the same issue and still no solution. I took off my pc3, swapped fuel injectors thinking they were clogged, and ran seafoam through. Im wondering if it has to do with the butterfly valves? might be really off but my exup gives me the error code because I have a full system and disconnected it and im wondering if that affected the valves? interested in peoples theories!
06 r6
11-02-2012, 07:22 PM
#3
Two Bro's=ORGASM *nohomo*
Bike: 07 R1
Originally Posted by
Paxter
You have a t-tuner mid pipe and they took out the map?? YIKES!
Get the MJS map uploaded in that puppy asap or send your ECU to OhioYJ and get the fuel map flashed right in.
He can also bump the idle a bit to help with the almost stalling, although probably a bandaid fix for the issue.
-Jamie M.
07 R1 -
Flash tune 'd,
A&R Race Baffles with Akrapovic Y Pipe (
wrapped in DEI Titanium header wrap ),
Renthal MX Kevlar Grips, HVMP Extra Heavy Weight bar ends, Saddlemen "Tech" seat (memory foam + gel), Skeen Racing Extended White frame sliders, Shermoto Levers, Proton flush mount front signals , BMC race filter,
Elka Stage 4 adjustable shock ,
iPod 4th Gen with Harry's Lap Timer Pro with Emprum UltiMate 5hz GPS and Ram mount, 190/55
Bridgestone S20 's,
Garmin 2595LM GPS in RAM stem mount,
MikeyMoto Ultralight rear rotor , Ultra
high power LED running lights , trimmed
ebay fender eliminator , Shorai LFX14A4-BS12 ultralight battery, Fren Tubo Type 4 CF lines (front and rear), Vesrah RJL front pads, Ferodo Sinter Grip ST rear pads, Amsoil MCF full synthetic oil, Amsoil EA15K13 car oil filter, Wurth HHS2000 chain lube, Shell 91 octane NO ETHANOL fuel ONLY.
Coming soon: Race Tech fork kit, EK MVXZ 520 chain, Drive Systems USA Superlite Steel rear sprocket (+2/47t), Driven drilled steel front sprocket (-1/16t), will try to reach top speed of 305kph/190mph.
11-02-2012, 08:04 PM
#4
Bike: 06 YZF R6
Where is the MJS map? I just found my cable for my PC so I hope to get it done soon
-2006 R6 Raven
Blue Angel/
-1978 Trans Am
11-02-2012, 08:10 PM
#5
Bike: 07 R1
Paxter
In OhioYJ's super mind blowing sticky at the top of this section.
I'll link it for ya:
http://www.r6-forum.com/forums/showt...22#post2100522
-Jamie M.
07 R1 -
Flash tune 'd,
Bridgestone S20 's,
11-02-2012, 08:17 PM
#6
Bike: 06 YZF R6
I am totally blind! Thank you!
-2006 R6 Raven
Blue Angel/
-1978 Trans Am
Linear Mode
