06 R6 cct install, how to release spring? : Yamaha R6 : R6 Forum
Old 11-02-2012, 02:09 PM   #1
WhistlerX
Hi all,
I just installed a new cam chain tensioner on my 06 r6 but can't figure out how to get the spring to release. According to the manual if the engine is not taken apart, I should put the kill switch in the off position and try to crank it, but it doesn't seem to do anything? Turn the key, pop in clutch, hold ignition button for .5-1.0 sec as the manual says, but I didn't hear it disengage spring locking mechanism... anyone know how to make the cct spring engage?? thnx!
WhistlerX is offline   Reply With Quote
Old 11-02-2012, 02:23 PM   #2
bryan j
pin it to win it
bryan j's Avatar
Bike: 07 r6, 06 yz250f
Turn the crank with a 14mm, might be a 12mm.
mods: woodcraft clipons and frame sliiders, leo vince slip on, 05 header mod, pcv, agg smog block offs and sbk res kit, robby moto sbk rearsets, 520 -1+2 renthal.set up, bauce racing ecu flash, ebc hh pads, and some small cosmetic stuff.
support the forum vendors.
bryan j is offline   Reply With Quote
Old 11-02-2012, 04:08 PM   #3
WhistlerX
Re: 06 R6 cct install, how to release spring?
Thanks Bryan_J, it was 12mm for the crank bolt, rotated it clockwise a couple times and the cct finally finally popped like it was supposed to. Sounds sooo much better and rides much smoother now in the 4-8k range I appreciate it man!
Old 11-02-2012, 04:32 PM   #4
bryan j
pin it to win it
bryan j's Avatar
Old 11-02-2012, 07:27 PM   #5
Darthteddy
Box of Lube
Darthteddy's Avatar
Bike: 2007 R6
How many miles did you get on the stock one. Im at 14 and im pretty sure its donezo.
07 Metalic Green R6 - Totaled
08 R6 Raven - In progress
Leo Vince Factory R Exhaust, Shermoto Levers, Agg Block Off Plates. Work In progress.
Build Thread
http://www.r6-forum.com/forums/showt...=1#post2895049
Darthteddy is offline   Reply With Quote
Old 11-02-2012, 07:54 PM   #6
bryan j
pin it to win it
bryan j's Avatar
I'm at 26k and mine is still good
Driven D-axis rear set spring install? topherchris Appearance and Exterior Mods 6 07-22-2011 05:34 AM
Installing Tension Spring and Torsion Spring Flancy2000 How To's... 0 08-21-2008 07:57 PM
'08 Model Release date? Imunfathomable General Discussions 7 08-11-2007 08:12 AM
06 R6 Final Release SpidermanSS Main Page News 63 01-24-2006 05:34 PM
2005 R6 RELEASE!!!! jdm9flow General Discussions 4 09-22-2004 02:28 PM
