'04 to '05 front end conversion : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Bike Build Forum
Old 11-04-2012, 06:58 PM   #1
Sick
Hello all,
I was encouraged to share my project with everyone, so here it is. No big deal, just swapping my 2004 R6 conventional forks and calipers for the better and beefier '05 inverted forks and radial mounted calipers.
The driving force for the swap was mainly wanting better brakes for the street. The conventional brakes were fine in most situations, but in others, I could definitely see some room for improvement.
The hardest part of the entire job was really just getting the brake lines squared away. I was under the impression that the SS lines I already had on the bike would have worked, but the right side line was just a couple inches too short. After ordering new Spiegler lines from STG, I had to use the '05 horn bracket assembly, but modify it to accept the aftermarket lines. And btw, I think the fitting adjustment tool Spiegler includes with the lines are junk. But the lines themselves are fine, IMO.
So here are some pics….
Before:
During:
Almost Done:
Finally:
Sick is offline   Reply With Quote
Old 11-04-2012, 08:30 PM   #2
ridick_bowen
Recreational Stuntrider
ridick_bowen's Avatar
Bike: 03 R6 Stuntbike
Re: '04 to '05 front end conversion
Nice work buddy! Your steering damper works on the new setup?
Originally Posted by R6_350z View Post
not putting miles on your bike because you want to keep it new is like not having sex with your wife because your saving her for the next guy
ridick_bowen is offline   Reply With Quote
Old 11-05-2012, 09:24 AM   #3
Sick
Yea, thankfully was able to keep the Scott's with the '05 front.
Consequently, I have the '04 conventional front end available if anyone needs it. Let me know, good price for it.
Old 11-05-2012, 04:52 PM   #4
grandboy2
Did you change the rotors also?
grandboy2 is offline   Reply With Quote
Old 11-05-2012, 06:12 PM   #5
lopez95632
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
How much were you able to pick up the 05 front.end for? Did you have to.change out the tripples?
must read for new members
lopez95632 is offline   Reply With Quote
Old 11-06-2012, 03:27 AM   #6
add2477
I just love your forum.Thanks for posting it.ssd drives price in Pakistan it have something that someone comeback again….there is a lot of useful information a person can get from here…windows price in pakitan I must say,well done.A good forum with great discussion and a good users,which contribute in the forum
add2477 is offline   Reply With Quote
Old 11-06-2012, 09:49 AM   #7
Sick
@grandboy
Yea you have to swap the rotors when switching to the '05 front end with radial calipers. The '04 rotors are 290mm and the '05 rotors are 310mm.
@lopez
I grabbed the forks, rotors, calipers, lower tripple and stem for about $400 or so. Had to buy an upper tripple tree and I bought clips ons for it as well. You do have to use different triples because the inverted forks are bigger (I think 50mm if I remember correctly, up from 41mm), so they '04 trips wouldn't fit the new forks.
Old 11-06-2012, 05:48 PM   #8
Phrozen
My R6 ate me
Phrozen's Avatar
Bike: 07 R6s
For anyone else that is wondering how to...
Parts needed:
Forks ('05 o r'06 & up) '05 are 8mm longer, '06-07 same height, '08 & up are 10mm longer
Front Fender ('05 or '06 & up) 05 is an R1 fender, 06 & up is the newer front fender
Clipons (from' 05) works the best
Upper & Lower Triple Trees (from '05) works the best
Brake rotors ('05 or '06 & up) the carrier looks different but same size
Brake Calipers and bolts ('05 & up) all the same, gold or silver
Brake Master Cylinder w/ brake lever (05 & up) also need the banjo bolt
Brake lines (05 & up)
Horn Bracket and plastic shield (from 05)
Front axle ('05 & up)
120/70/17 Front Tire instead of the 120/60/17
You can make the 06 & up triples work by either shimming the stem under the upper
triple tree or by pressing the stem out of the lower and swapping it. Clipons under the
triple tree interfere with the ram air tube covers. Like I said you can make the 06 & up
Trees and clipons work but the geometry is different in the trees and it will actually
shorten the wheelbase. I recomend the 2005 Triple trees but the forks don't matter as
much as long as you set the height right.
Modifications- PCV w/ Autotune & LCD, GraveSport Slip-on, Slide Stops, K&N filter, Factory Pro +4 Ignition rotor, SuperFlare Velocity Stacks, AGG block off plates, Fren Tubo Type 4's, YEC Brake pads, 530 Chain Conversion, Penske 8987 shock, 07 USD Forks and Brakes in 05 Triples, ASV C5 Levers, Scotts Steering Damper, GYTR Carbon Chain Guard, GYTR Carbon Toe Guard, Canadian GYTR Frame Sliders, GYTR Carbon Tank Pad, BST Carbon Rear Fender, Competition Werks Fender Eliminator, UFO Integrated Tail Light, Michelin Pures, Gilles Chain Adjusters & Lifters, Gilles Rear-sets, Powder Coated Passenger Rear-sets, GYTR Seat Cowl, SaddleMen Seat, Irate Customs Grill, Gregg's Flush Mount Signals, DDM 5K H.I.D.'s, Amsoil 10W-40, Integrated Beltronics 985, and
Phrozen is offline   Reply With Quote
Old 11-07-2012, 10:12 AM   #9
Sick
Awesome, thanks Phrozen. Hopefully that will help some others out in the future. And fyi, I believe the 120/60 tire can be used without any problem.
R6s to R6R front end conversion. jusmad Suspension settings 4 07-09-2011 10:58 AM
05 Front Conversion? A John In NJ General Discussions 1 07-29-2010 09:46 AM
00 R6 520 Chain Conversion help- front sproket prkid424 Garage / Mechanical Help 7 03-19-2009 01:05 PM
R6-R1 Front Conversion? Outlaw122 Appearance and Exterior Mods 6 06-17-2008 01:16 PM
520 conversion vs -1 in front?? a1yola Garage / Mechanical Help 9 11-03-2006 07:03 AM
