Question about D2s bulbs - Projectors : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 11-05-2012, 07:07 PM   #1
sgt27towner
no glove, no love
sgt27towner's Avatar
Bike: 09 R6
I have custom projectors and one of the bulbs went out. I purchased a new bulb and the back doesn't look like it match the ones that were originally in there - mine has wires, and the new ones don't. Here's a pic. Any help is appreciated.
Original bulb (Left) New bulb (right)
sgt27towner is offline   Reply With Quote
Old 11-05-2012, 07:37 PM   #2
jhpr6
Bike: 07 Yamaha R6s
Re: Question about D2s bulbs - Projectors
oh actually, the one you have is definitely customized...
jhpr6 is offline   Reply With Quote
Old 11-05-2012, 09:26 PM   #3
legendes
legendes's Avatar
Bike: 09 R6 Raven
some aftermarket d2s bulbs are like that so they work with the HID AMP connectors
like this, but they're called D2H
theretrofitsource sells them also:
http://www.theretrofitsource.com/pro...oducts_id=4126
but that would be the first i have seen them with spade connectors
but those notches on the round base should be correct to fit your projector though.
curious though how much did you buy it for? and did you get it because you wanted to match the 6000k bulb that you originally had?
legendes is offline   Reply With Quote
Old 11-07-2012, 10:23 AM   #4
PacmanR6
Vroommm
PacmanR6's Avatar
Bike: White Rice
Send a message via AIM to PacmanR6
My D2S bulbs most certainly do have wires in them, and even the replacements i got for them do. D2H bulbs are meant for halogen housings, D2S are meant for projectors, find somewhere else to buy them.
PacmanR6 is offline   Reply With Quote
Old 11-07-2012, 11:31 AM   #5
legendes
legendes's Avatar
Bike: 09 R6 Raven
Uhhh sorry but thats not true
If you look at any oem d2s bulb you'll see the round base for the oem P32-D connector just like in the pic of the bulb on the right that the op posted
Replacements may or may not come with the wire connectors(AMP) or the round base (P32-D). the one in the op's pic is clearly an aftermarket bulb so it can be purchased both ways it just depends on where you get it from.
And in regards to d2h...
On TRS's page it even says what the d2h is for:
"Made to fit in standard D2S Xenon or Bi-xenon Projectors, these will perform the same as a normal D2S bulb, but leave you with at least an extra half inch of clearance compared to a typical D2S socket. Requires the use of AMP output ballasts or D2S to AMP adapters with OEM ballasts."
D2h is an aftermarket bulb made to make it easier for retrofitters of oem projectors able to use it with aftermarket ballasts
Since its clarified that d2h is an aftermarket replacement for d2s, no halogen based housing would be able to accept a d2h/d2s bulb
Old 11-07-2012, 11:35 AM   #6
legendes
legendes's Avatar
Bike: 09 R6 Raven
Op, also youcan still use the bulb on the right, you would just need an AMP to P32-D adapter, of course it might just be cheaper to get one with the proper termination
Old 11-08-2012, 12:45 AM   #7
dixoeileen
dixoeileen is offline   Reply With Quote
Krypton projectors bulbs? r6_andrew Appearance and Exterior Mods 4 08-23-2012 08:05 PM
Krypton bulbs projectors Color questions mtbprodigy Appearance and Exterior Mods 11 05-25-2011 08:35 PM
Krypton bulbs or xdcycle/sportbikelites projectors Deee7965 General Discussions 22 11-18-2010 09:44 AM
OEM projectors-ballasts-bulbs+more ae8620v Bikes Parts For Sale 12 04-20-2010 02:42 PM
FS: Projectors, Bulbs, Strobes, LEDs, Lenses etc... misterjj Bikes Parts For Sale 7 04-07-2009 10:16 PM
