Pretty sure it's a clutch issue? : Yamaha R6 : R6 Forum
Old 11-06-2012, 04:20 PM   #1
jdthedude
jdthedude's Avatar
Bike: 2006 R6S
Angry Pretty sure it's a clutch issue?
Background, I'm on a '06 R6S, it has 40k miles on it, only major maintenance that has been done has been a valve adjustment. Rode it on a Thursday, it sat till Monday, got on it started it up and the speedo started jumping around to 8-9 mph. Thought it was strange but I was already late for work so I jump on put it in gear let go of the clutch (which the lever felt normal) and the speedo moves but the bike doesn't. No strange noise, no hint of pull. With the bike off and I put it in gear I can push it around like its in neutral? I've talked to a couple of mechanic friends of mine and they all say clutch. My thing, why didn't it start slipping? I rode it Thursday and it felt 100% fine. Not a hint of slipping or anything. Ready, set, go. What's going on?
"For you, sir, may the jaws of death have cotton teeth." ~ "Jitterbug Perfume" by Tom Robbins
jdthedude is offline   Reply With Quote
Old 11-06-2012, 04:37 PM   #2
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
Re: Pretty sure it's a clutch issue?
pull the cover off, remove the pressure plate, measure the fibers. If 2.85mm or less, they are done. It may have been slippin a little before, ya just didn't notice it. Be sure the lever has free play, but only other way to know is to measure the fibers, and the stack height.
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 11-06-2012, 05:54 PM   #3
Phrozen
My R6 ate me
Phrozen's Avatar
Bike: 07 R6s
Nope, I bet the sprocket nut fell off.... only way your going to get a speedo reading in nuetral and in gear. Tranny is spinning to give the speed reading.
Modifications- PCV w/ Autotune & LCD, GraveSport Slip-on, Slide Stops, K&N filter, Factory Pro +4 Ignition rotor, SuperFlare Velocity Stacks, AGG block off plates, Fren Tubo Type 4's, YEC Brake pads, 530 Chain Conversion, Penske 8987 shock, 07 USD Forks and Brakes in 05 Triples, ASV C5 Levers, Scotts Steering Damper, GYTR Carbon Chain Guard, GYTR Carbon Toe Guard, Canadian GYTR Frame Sliders, GYTR Carbon Tank Pad, BST Carbon Rear Fender, Competition Werks Fender Eliminator, UFO Integrated Tail Light, Michelin Pures, Gilles Chain Adjusters & Lifters, Gilles Rear-sets, Powder Coated Passenger Rear-sets, GYTR Seat Cowl, SaddleMen Seat, Irate Customs Grill, Gregg's Flush Mount Signals, DDM 5K H.I.D.'s, Amsoil 10W-40, Integrated Beltronics 985, and
Phrozen is offline   Reply With Quote
Old 11-06-2012, 07:39 PM   #4
MELK-MAN
MELK-MAN's Avatar
worth a look for sure, didn't catch the part about the speedo reading mph.
Old 11-06-2012, 09:57 PM   #5
jdthedude
jdthedude's Avatar
Bike: 2006 R6S
I thought about that nut too, but I figured there would be more noise or rattling coming from there. I've heard of that before, that nut coming off. I hope that's all it is. Unfortunately I have to use my ride day Saturday to tear it down. Which means no ride. Any advice on how to keep that nut on there. I bent the washer last time I did it, after I torqued it to the service manual specs. Which is how it came so.. Lock tight? Heavier washer?
Old 11-07-2012, 06:24 AM   #6
Phrozen
My R6 ate me
Phrozen's Avatar
Bike: 07 R6s
Loctite is your friend.....put a bunch of blue on it and you should not have that problem anymore.
Old 11-07-2012, 07:39 AM   #7
MELK-MAN
MELK-MAN's Avatar
proper torque, and the stock washer folded over should do fine. it's when the sprocket nut isn't tight enough that it usually comes loose. i have never used locktite, but my sprockets are on and off quite a bit.. i would use a dab.
Old 11-08-2012, 05:45 AM   #8
jdthedude
jdthedude's Avatar
Bike: 2006 R6S
It was the nut. Looks like the threads just wore down enough for it to pop off. Thanks for the help guys!
Sent from my iPhone using Motorcycle.com App
Old 11-09-2012, 01:39 AM   #9
dexter6
Features:
Earn 50,000 Discount Coupons philosophy Coupon Codes bonus Avios Points after your first use of he card
Plus, earn an additional 25,000 bonus Avios Points after you make $10,000 in purchases within the first Online Coupons year of account opening.
Two facts:
dexter6 is offline   Reply With Quote
Clutch issue (06) ErikTaylor General Discussions 7 07-09-2012 08:42 AM
Clutch issue? Megah Garage / Mechanical Help 3 05-27-2012 02:44 PM
Oil and clutch issue. scorchx1245 Oil and Lubrication 3 03-27-2011 01:55 AM
99 r6 clutch issue farmstar Garage / Mechanical Help 1 04-02-2008 06:29 PM
Clutch issue buchern Garage / Mechanical Help 0 01-15-2007 03:02 PM
