help: bazzaz order : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 11-07-2012, 03:25 AM   #1
timthy10
timthy10's Avatar
Bike: R6 2004
Exclamation help: bazzaz order
hi all hope this is in the ryt section. im from cape town south africa and im looking to get the bazzaz for and auto tune for my r6 2004. iv loked on ebay but cant find any listed for my bike. so i was wondering if any of you guys could help me get one coz they so expensive here in south africa. i have an aunt who stays in america and is coming down in december and she said she would bring it down. a second hand one is gud enough for me could you pls try and organise something for me or give me the details so i could make payments etc. im also lookin for a working tps if any one has one, thnks
ps im new by the way, got my bike last month
timthy10 is offline   Reply With Quote
Old 11-07-2012, 04:50 AM   #2
timthy10
timthy10's Avatar
Bike: R6 2004
Re: help: bazzaz order
please help i need these things before december
Old 11-07-2012, 07:17 AM   #3
tdoss1980
nova r6
tdoss1980's Avatar
Bike: 05 r6 raven
Bazzaz doesn't make a unit for the second generation R6's (03-05 +06-09 R6s) per their website just 2006 and newer. However you can get a PCV with autotune
2005 r6 raven, Motodynamic sequential signals, flush smoke front turns, 8k hid low, Devil racer carbon highmount ceramic coated black, Ohlins steering dampner, Motovation no cut frame sliders and bar end sliders, ASV levers, Vortex black rearsets, Corbin seat, K&n air filter, Factory Pro +4 ignition advancer, superflare vstacks, and slide stops, -1 520 conversion, Goodridge Shadow brake lines, Zero gravity windscreen, Stompgrip tank pads, NRC powdercoated racing covers, HINSON SLIPPER CLUTCH, Vented Brakes cooling system, Racetech internals front and rear with Michelin Power Pures holding it to the road
tdoss1980 is offline   Reply With Quote
Old 11-07-2012, 07:28 AM   #4
timthy10
timthy10's Avatar
Bike: R6 2004
alryt thanks for the reply, what are the costs for it there? probably cheeper thn here, and any info about a working tps for sale?
Old 11-07-2012, 07:42 AM   #5
tdoss1980
nova r6
tdoss1980's Avatar
Bike: 05 r6 raven
Most PCV's go for around 300 usd and the autotune is around 250, is there something wrong with your tps sensor?
Old 11-07-2012, 08:07 AM   #6
timthy10
timthy10's Avatar
Bike: R6 2004
apparently i can only get a pc3 for my bike is this true? pls any!?
Old 11-07-2012, 08:10 AM   #7
timthy10
timthy10's Avatar
Bike: R6 2004
yes my close throttle value is 16 my w/0 throttle is 87. my idle is rough and the bike is really jumpy around 10k rpm, the dealers here said that it looks like its a tps probably so i should replace tht before doing further tests
Old 11-07-2012, 08:56 AM   #8
tdoss1980
nova r6
tdoss1980's Avatar
Bike: 05 r6 raven
Get the PCV for the 06-09 R6s its the same bike as yours
Here is the service manual for the bike
http://www.r6messagenet.com/forums/p...ice_manual.pdf
In there it details how to check the tps sensor voltage to see if the sensor is bad and how to adjust it.
also on page 341 it shows the suggested values on the TPS, closed should be 15-17 and wide open should be between 97-100
Old 11-07-2012, 12:51 PM   #9
timthy10
timthy10's Avatar
Bike: R6 2004
if you cant get both those numbers in the parametrs which one should i put with in that parameter, the close throttle or open throttle thanks, i already cleaned it with switch cleaner a few times helped the idle a bit
Old 11-07-2012, 05:35 PM   #10
tdoss1980
nova r6
tdoss1980's Avatar
Bike: 05 r6 raven
I would guess the wide open throttle if it were me
Anyone been able to order from... FordF150 General Discussions 6 08-17-2012 06:00 AM
Ever order from bimoto.eu? chrischoi General Discussions 0 05-23-2009 02:16 AM
best place to order? BEAVIS General Discussions 8 09-10-2008 08:21 AM
New R6 on order!! yoda General Discussions 3 02-10-2006 10:03 PM
