bad shock?!?? : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 11-07-2012, 08:05 AM   #1
blammomike
bad shock?!??
just bought the r6 01 and dude told me needs rear shock how can I tell if it does
blammomike is offline   Reply With Quote
Old 11-07-2012, 08:15 AM   #2
Mr. Azim
Mr. Azim's Avatar
Re: bad shock?!??
Stock or aftermarket?
It might just need a refresh or spring replacement
Either the seals have gone bad and it is leaking oil or needs a oil refresh OR the spring has lost its springy-ness and needs to be replaced.
To check the seals, click the adjusters left/right (make note of how many clicks). If they turn freely and easily the seals are okay. A sure way to check is to take it for a good ride and see if there is any oil leaking out from the adjusters.
To check the spring, push down on the seat and see how the bike reacts.... turn the rebound a good amount of turns soft and note the difference (should bounce up really fast) then turn it way hard and see the difference (should bounce up really slow).
If you're getting the same reaction from all settings, the spring and oil could be low/bad or just dirty.
It takes a lot for a shock to be thrown into the garbage.
SOAR Novice #84
2006 Yamaha YZF-R6
2013 Sponsors/Supporters
Trackside Cuts Custom Leather & Vinyl
MikeyMoto Racing Lightweight Brake Rotors
Bluestreak Racing Motorcycle Parts & Accessories
Vortex Racing Motorcycle Parts & Accessories
Mr. Azim is offline   Reply With Quote
Old 11-07-2012, 08:22 AM   #3
blammomike
Re: bad shock?!??
gotya going to check it out when i get home
Old 11-09-2012, 07:32 PM   #4
blammomike
Re: bad shock?!??
ok i found a red shock on ebay it says it fits 01 r6 but the cylinder for ajusting is vertical not horizontal will this work. the one i have is yellow any thoughts
03-05 R6 Racetech Shock and Stock Shock rockdicasbah Bikes Parts For Sale 4 04-02-2013 08:59 PM
06 Shock on an 05 petervang Garage / Mechanical Help 1 12-18-2010 02:25 AM
06-09 R6 rear shock..(yellow spring), R6 shock Joken Bikes Parts For Sale 0 08-15-2010 08:54 AM
***fs: Ohlins Ttx Ya789 Rear Shock 06-09 R6 Best Shock Offered For R6**** JE824016 Bikes Parts For Sale 26 06-07-2009 09:13 AM
shock arm r6kid General Discussions 0 08-19-2008 06:42 PM
