THis is BS! check this out : Yamaha R6 : R6 Forum
Old 11-07-2012, 03:27 PM   #1
kipmedford
Bike: 07 r6s
So check this out!!!!!!
I have a 07 r6s with 05 fairings... So i wnet to change my fairings with the new ones i bought.. so i also painted my tank.. welllllll... i took the air box off in the mean time waiting for the paint to dry... and shot carb cleaner into the throttle body ... to spruce it up.. it was idling ruff! thought it might help.. so after insatlling everything back fairings and all i go to ride and it is running on 3 cyclinders! so i exam and find which one is not running by puttung water on ehxaust pipes.. so i change all spark plugs and take fuel injectors off to exsm them.. all is well.. so i take the cyclinders injector that wasnt running and put into another cyclinder... to see if it is faulty... cauz that would cause the cyclinder it is in now not to run.. also i changed the park plugs ..so put it all back together... all 4 cyclinders are running good and strong.. BUT>>>>>> now mi idle is sitting at 3,500/3,600 rpms...wtf? i exam idle screw... i unscrew it to were it is not even touchn the throttle... still 3,600 rpms... i now suspect a vaccum leak... so i spray carb cleaner around and it idled higher bearly i mean just bearly around the throttle boddy boots that conect to the mootor.. so i take off the throttle body and inspect boots.. they r perfect.. re install throttle body and connect everyhting.. still 3,600... wtf i am stumped... PLEASE HELP ME also i sprayed so carb cleaner around again after i put it back together.. AGAIN.. and in the front by the spark plugs there was a section that i sprayed by the 2nd plug (2nd plug from the left if u were sitting on the bike) and it idle bearly i mean just bearly again higher.. wtf could be up there by the plugs that might be causing a vaccum leak if at all a vaccum leak is the problem???? plzzzzzz help me...... plz thanks guys
kipmedford is offline   Reply With Quote
Old 11-07-2012, 03:47 PM   #2
OhioYJ
OhioYJ's Avatar
Re: THis is BS! check this out
Can you compile that into a readable form? Thats painful to even try and sort through.
OhioYJ is offline   Reply With Quote
Old 11-07-2012, 03:54 PM   #3
lopez95632
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
Sweet baby Jesus!!! I think there is a second idle screw somewhere on the throttle body. I think stunters mess with it to get it up higher then what the idler screw on the outside would allow.
must read for new members
lopez95632 is offline   Reply With Quote
Old 11-07-2012, 04:08 PM   #4
ak2007r6
Lifetime Premium
ak2007r6's Avatar
Bike: A snail
Your bike idles like a bear?? That's badass, I bet it sounds awesome!
Originally Posted by TheOtherHalf View Post
Got permission from the hubby to get out of the kitchen and post on a thread
Originally Posted by GIJoe007 View Post
"Never try and teach a pig how to sing. It just wastes your time and pisses off the pig."
RIP Jason (snocompton) you were an amazing guy and will be missed
ak2007r6 is offline   Reply With Quote
Old 11-07-2012, 04:16 PM   #5
yuengling910
Late Breaker
yuengling910's Avatar
Bike: 07 R6S
Throttle freeplay?
yuengling910 is online now   Reply With Quote
check check bitches Blue 08 R6 Test section 10 03-04-2013 01:44 AM
how to check a Check engine light on a 2004 R6 1g jacob General Discussions 1 06-27-2010 03:51 PM
check check one twooo Xyster Test section 1 09-21-2009 02:40 AM
Can someone check for me? 04focaR6 General Discussions 3 10-15-2006 01:59 PM
Check this out SpidermanSS General Discussions 6 10-07-2006 04:36 AM
