I was tightening a bolt down on my 07 r6 and it sheared right off. now it is slowly leaking oil out of the threads. the bolt head sheared off and the rest is still inside. i have a ez out i planned on using that to get it out and put a new one in. i just dont know what i would call it. heres some pics of where it is.
07 r6 7000 miles and counting......
That's a stator cover bolt, but it's not the one that SUPPOSED to be in that spot... They're all supposed to look like the bolts that are on either side of your sheared one. Where did you get that, and who convinced you to put that bolt in that spot?
Part number 26
would replace number 27 since your there
__________________ 2005 r6 raven, Motodynamic sequential signals, flush smoke front turns, 8k hid low, Devil racer carbon highmount ceramic coated black, Ohlins steering dampner, Motovation no cut frame sliders and bar end sliders, ASV levers, Vortex black rearsets, Corbin seat, K&n air filter, Factory Pro +4 ignition advancer, superflare vstacks, and slide stops, -1 520 conversion, Goodridge Shadow brake lines, Zero gravity windscreen, Stompgrip tank pads, NRC powdercoated racing covers, HINSON SLIPPER CLUTCH, Vented Brakes cooling system, Racetech internals front and rear with Michelin Power Pures holding it to the road
If that is the only place that is leaking when you get the new bolt you can use a lil gasket glue on the treads to keep it from leaking. More than likely it will stop leaking when you put a new bolt in there anyways cuz the head of the bolt holds the pressure against the cover to keep the cover sealed. Make sure you torque instead of guessing that is how u snap bolts lol locktite is you friend.
Thanks for all the replies. im going up to my local dealer and seeing if they have what i need. only part that sucks is when i pull that bolt out i will lose alot of fresh oil haha
