Idle issues 2006 R6 Race : Yamaha R6 : R6 Forum
Old 11-08-2012, 04:33 PM   #1
apexhugger
Have an 06 R6 with 15k on it...full Termi exhaust. When i first bought this summer i noticed that every now and then it would cut off after quick acceleration (in first gear) once i pulled in the clutch. No big deal.
Fast forward to yesterday (now that I am selling), I went to start up with no problem. The battery was little weak but otherwise all is good. Once it warmed up to about 115 I reved it up one good time and it cut off (after the rev). I try to start it back up and i had to give it gas and keep giving it throttle or it would die. 10 minutes later I started it up and all was fine.
Same thing happened today. What is can cause this? I'm thinking it either has to do with a weak battery or the temp (exhaust). Someone mentioned back pressure on my term which would require remapping but im not sure. It's being sold in two days so I would like to get this straightened out ASAP.
Never mistake passion for anger
apexhugger is offline   Reply With Quote
Old 11-09-2012, 05:17 PM   #2
apexhugger
Re: Idle issues 2006 R6 Race
was the battery in case anyone has the same issue.
Old 11-11-2012, 10:12 PM   #3
mknuchell
live to ride
mknuchell's Avatar
Bike: 07 R6 charcoal
Send a message via Skype™ to mknuchell
I have this exact same problem. You can check my thread if you'd like. From what I've heard for the past year is that the 06 - 07 models have this issue and nobody can explain why. I've tried fuel mapping and replacing plugs coils cleaning air filter. The only thing I havnt done is a valve adjustment but for me once the bike is warmed above 140ish the problem goes away and I hear if it's warm it gets worse if it's the valves. Let me know if you find anything. Some people also have said the clutch sensor could be the issue*
mknuchell is offline   Reply With Quote
Old 11-11-2012, 10:13 PM   #4
mknuchell
live to ride
mknuchell's Avatar
Whoops nevermind ignore the last post
Help: Idle Issues Zimmer Garage / Mechanical Help 6 06-19-2011 09:46 PM
'01 R6 Idle Issues Shocker69 Garage / Mechanical Help 1 03-14-2011 04:16 PM
Low Idle Issues Belo Exhaust and fuel delivery 7 09-05-2010 07:07 AM
04 Idle issues jd77 How To's... 1 12-12-2008 04:53 PM
Idle Issues for 05' R6 Velocity Exhaust and fuel delivery 4 02-26-2007 01:49 PM
Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
