Fork oil question : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 11-09-2012, 06:30 AM   #1
Dow Jones
Bike: 05 R6
Fork oil question
About 3 months ago I replaced the fork oil and seals. I used the kit from traxxion and measured the fork oil from the top of the fork without the spring to what was in the service manual. I believe maybe I used the wrong fork oil. Since then even with the compression and rebound set to full soft the front is very very springy. I usually ride with the clutch covered and its so harsh it sometimes knocks my hand off the handlebar. At night when I'm riding I can see the beam of my headlights going up and down drastically on a car I'm following.
My sag settings are within the ballpark for my weight.
The fork oil listed below is what I used. I used the light viscosity which I believe is 5 wt even though their website shows it as 50wt
http://www.bikebandit.com/silkolene-fork-oil
Would that oil cause that much of a drastic change? Also using a zip tie I still have about 1 1/2 inch of travel that the fork is not using.
If the fork oil is the problem. Would this oil be a better choice.
http://www.bikebandit.com/silkolene-...spension-fluid
Dow Jones is offline   Reply With Quote
Old 11-09-2012, 03:32 PM   #2
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
Re: Fork oil question
5wt fork oil is fine and is what is typically used.. the reason your forks feel "springy" is likely cause you set em to full soft.
Street riding, and having 1.5" of travel left, is not an issue either. it's not likely you are going to go fast enough, and brake hard enough, to use all the travel on the street.
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 11-09-2012, 03:39 PM   #3
redisdeadrideblue
Official Noob Greeter
redisdeadrideblue's Avatar
Bike: some stupid ones
Settings are way off it sounds like. Much more than 5wt and the ride gets pretty stiff. I used maxima 10wt in my 08 when I had it and it was pretty stiff, but I also had it set up for the track so thats pretty normal.
redisdeadrideblue is offline   Reply With Quote
Old 11-09-2012, 04:24 PM   #4
mercenary
When in doubtThrottle out
mercenary's Avatar
Bike: Yes Please
2010 YZF-R6 Blue Street Cruiser
2009 YZF-R6 Backup Track whore
2008 YZF-R6 Primary Track whore
MCRA #81
CCS#81
mercenary is offline   Reply With Quote
Old 11-09-2012, 10:58 PM   #5
Dow Jones
Bike: 05 R6
Well for the past month or so I have tried many different combinations and it never feels like how it felt before. It's like I'm riding jack hammer.
Old 11-09-2012, 11:02 PM   #6
Dow Jones
Bike: 05 R6
I'm sure the settings are way off cause I can tell that just from riding. I tried using the settings posted on sportrider magazine site but no matter what I try the ride just feels like shit.
I started with all of the settings in the middle but can't get it back to the normal feel. I used to commute to work on the bike and put down almost 20K miles on this bike but after the fork service it's almost unrideable.
Old 11-09-2012, 11:04 PM   #7
Dow Jones
Bike: 05 R6
Originally Posted by mercenary View Post
Glad I could assist you in adding to your postcount. If you would like to join the discussion with some substance other than a google image search of lulz I'm all ears.
Old 11-10-2012, 06:14 AM   #8
MELK-MAN
MELK-MAN's Avatar
so you had it serviced, and now no matter what something doesn't feel right regardless of settings? it's possible something wasn't put together correctly, or the fork oil level is way off. take it back, or .. if it were me.. have a suspension specialist check things out. get some photos or something in writing from the real suspension tech to get your money back from the first guy. (if something is in fact found to be wrong).
SILKOLENE makes awesome stuff.. either of those two fork oil choices you posted would be just fine. one is just more expensive and engineered for racing purposes.
Old 11-10-2012, 11:34 AM   #9
mercenary
mercenary's Avatar
Bike: Yes Please
I appreciate that, the fact that you expected to get awesome dampening out of turning the valves all the way open is astounding. What exactly did you expect by opening them all the way? Did you expect a refresh to allow you to use no dampening at all?
MCRA #81
CCS#81
Old 11-10-2012, 01:44 PM   #10
DanQ
Yamaha Blue in any color
DanQ's Avatar
Bike: FZR-1K, R1, Vmax, R6
What year bike?
How many clicks are on each of the damping adjusters right now (still full open (counterclockwise) or what?
Dan
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
05 V-Max 0098/2000 20th Anniversary
04 Roadstar Warrior
TEAM: SO FAST SO CLEAN
DanQ is offline   Reply With Quote
06-07 r6 fork question Be_ravenr6 Suspension settings 6 07-29-2012 10:09 PM
07 r6 fork oil question nico_gzertribe Suspension settings 9 04-16-2011 12:07 PM
02 fork oil question pensr6 Suspension settings 4 08-17-2008 06:08 PM
fork question?? Brendon Edelman General Discussions 3 06-11-2008 03:30 PM
Fork question 06 HardR6'n General Discussions 10 09-26-2007 12:38 PM
