» Site Navigation
» Motorcycle Forums
11-09-2012, 03:19 PM
#1
Box of Lube
Bike: 2007 R6
Nasty gunk in air box?
I'm in the process of changing my spark plugs due to the bike running a little odd the last 2 days, and found a little pool of oil in the bottom left corner. Also some build up of gunk along the upper rear center of it. I'm gonna assume its commingle from the crank case breather at the back of the air ox, and that its on the left side from being on the kickstand. What causes this on these motors and how do I remedy it?
Maybe from over filling the oil by a little bit? I'm at the top of the slashed section with the bike level on the dipstick.
Here's a pic. Excuse the poor quality from my cell phone.
11-09-2012, 08:43 PM
#2
crashing aint so bad
Bike: 2005 red r6
Re: Nasty gunk in air box?
Totally normal. The pcv vents into the air box as a way to increase ring sealing and somewhat reduce emissions. You can clean it all you want the oil will still come back. It is also a nice way to help collect dust that would ordinarily end up in the motor. Don't worry about it.
11-12-2012, 05:57 PM
#3
Two Bro's=ORGASM *nohomo*
Bike: 07 R1
Originally Posted by
Darthteddy
Are you screwing the dipstick in when you are checking the oil?
-Jamie M.
07 R1 -
Flash tune 'd,
A&R Race Baffles with Akrapovic Y Pipe (
wrapped in DEI Titanium header wrap ),
Renthal MX Kevlar Grips, HVMP Extra Heavy Weight bar ends, Saddlemen "Tech" seat (memory foam + gel), Skeen Racing Extended White frame sliders, Shermoto Levers, Proton flush mount front signals , BMC race filter,
Elka Stage 4 adjustable shock ,
iPod 4th Gen with Harry's Lap Timer Pro with Emprum UltiMate 5hz GPS and Ram mount, 190/55
Bridgestone S20 's,
Garmin 2595LM GPS in RAM stem mount,
MikeyMoto Ultralight rear rotor , Ultra
high power LED running lights , trimmed
ebay fender eliminator , Shorai LFX14A4-BS12 ultralight battery, Fren Tubo Type 4 CF lines (front and rear), Vesrah RJL front pads, Ferodo Sinter Grip ST rear pads, Amsoil MCF full synthetic oil, Amsoil EA15K13 car oil filter, Wurth HHS2000 chain lube, Shell 91 octane NO ETHANOL fuel ONLY.
Coming soon: Race Tech fork kit, EK MVXZ 520 chain, Drive Systems USA Superlite Steel rear sprocket (+2/47t), Driven drilled steel front sprocket (-1/16t), will try to reach top speed of 305kph/190mph.
11-12-2012, 07:03 PM
#4
Dirt track racing!
Bike: 2008 YZF R6 LE
luke geis
Oil has a vast number of benefits
11-13-2012, 05:26 AM
#5
Laugh now, cry later
Bike: 03 R6
|/3|\|0|\/|
Current bike: YZF-R6
MJS Shorty slip-on, K&N Filter
Old bike : FZ1 03
Aj-Agwa
why when i put the straight pipe on a i rev it to like 5 or greater RPM the bike turns off??
Dafuq?
11-13-2012, 05:46 AM
#6
Original Member-Vendor
Bike: 2007 R6, 2005 CRF250r
Thecca
icwudt.
11-13-2012, 07:22 AM
#7
Box of Lube
Bike: 2007 R6
toysareforboys
-Jamie M.
No. I was under the impression that you do it with bike flat and straight up, and dip stick not screwed in.
11-13-2012, 10:36 AM
#8
Bike: 07 R1
Darthteddy
That's correct, it was a trick question
-Jamie M.
07 R1 -
Flash tune 'd,
Bridgestone S20 's,
11-13-2012, 11:57 AM
#9
DANG university level exam question right thur.
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
11-13-2012, 12:14 PM
#10
Bike: 07 R1
natedogg624
Man, used to think that pounded back in the day. 48hz, lol
-Jamie M.
07 R1 -
Flash tune 'd,
Bridgestone S20 's,
Linear Mode
