Both INTAKE valves are stuck opened : Yamaha R6 : R6 Forum
Old 11-26-2012, 02:54 PM   #1
paan009
paan009's Avatar
Both IN. valves are stuck opened in the #2 cylinder.
No contact with the piston, but this definitely explains
why I couldn't get the motor to fire this past summer.
Any ideas and/or suggestions? Since I'm parting the motor,
I just want to know how I can sell the head in this condition.
Is it junk or just a valve keeper gone bad?
ID:	86855   Click image for larger version
1992 ZX7
1993 ZX950
2001 R6 Champions Ed.
2003 Zuma 49cc
2006 ZX10R
paan009 is offline   Reply With Quote
Old 11-27-2012, 08:33 AM   #2
Matchlessmingler
Matchlessmingler's Avatar
Bike: 2006 R6 Team Yamaha Blue
Re: Both INTAKE valves are stuck opened
My 2 cents but if the valves are stuck in open position it most probably is bent. They look tweaked at the valve head. This is likely to be a result of piston contact or perhaps dropped valves. Either way, it would require replacing the valves and valve guides. Hopefully someone with more experience will chime in and give you some options.
Some basic R6 outlines for those "digitally challenged" Crayola fans out there
1999 R6 Outline
2003 R6 Outline
2006 R6 Outline
Matchlessmingler is offline   Reply With Quote
Old 11-27-2012, 08:47 AM   #3
paan009
paan009's Avatar
Thanks for the reply: I carefully inspected the #2 piston and didn't see
any marks on it. Never had both valve do this, but I did float 1 valve and it
took out the piston and valve head on an over-rev when I missed a shift!
1992 ZX7
1993 ZX950
2003 Zuma 49cc
2006 ZX10R
Old 11-27-2012, 09:07 AM   #4
shnormo
Got street appeal?
shnormo's Avatar
Bike: '04 and '07 R6
Images: 1
Send a message via AIM to shnormo
Valves are most likely bent. only way to really check is to pull the valve keepers out
shnormo is offline   Reply With Quote
Old 11-27-2012, 10:51 AM   #5
LiveFastDieLast
Lifetime Premium
LiveFastDieLast's Avatar
Bike: 09 R6
As said above you will need to remove the vales for inspection.
If they are not visibly bent by eye or with a machinist square you will need some tools like this.
A indexing collet punch grinder
and a Height Guage with Dial Indicator attachment
A extremely flat surface will also be needed, A granite inspection table is the best but something level and flat should work.
The Valve will go in the Indexing Holder. Set the height gauge on the valve. and rotate the holder. This will give you a read out on the indicator and you can see if the valve is bent. You will see the dial indicator read from a positive to a negative number back and so on.
Or you will see very little movement on the gauge.
I have no idea what type of tolerance Yamaha has on the Valves but almost all dial indicators read out to .ooo1 of an inch
If you have any Tool and Die or machinist friends that will be the quickest way to get access to those tools.
Hope this help.
Keep your Knees in the Breeze
"Only two types of Whiskey I don't like, Dick and Throttle" - A Wise Man.
LiveFastDieLast is offline   Reply With Quote
Old 11-27-2012, 11:38 AM   #6
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Hope this help.
I don't think I'd buy ANY precise measuring tool off alibaba...
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
Old 11-27-2012, 12:54 PM   #7
LiveFastDieLast
Lifetime Premium
Bike: 09 R6
Just a photo for example. but I agree. I didn't even notice the name.. hahha
Old 11-27-2012, 03:55 PM   #8
paan009
paan009's Avatar
I have an auto race shop available to me.
Just these bike parts are so small compared
to the V8's they build!
1992 ZX7
1993 ZX950
2003 Zuma 49cc
2006 ZX10R
Old 11-27-2012, 06:29 PM   #9
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
what about the valve buckets for those 2 valves? Are they cracked? (the things the camshaft lobes hit to push the valve spring/valve downward). IF so, the head is JUNK.
If the valve is just bent, and the bucket easily comes out from on top of the spring, i suspect you can use a spring tool to remove the retainer/keepers, take the spring out, then beat the valve out. From there just replace the valve guide and valve..
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 11-27-2012, 06:34 PM   #10
paan009
paan009's Avatar
Buckets looked good, but I'll pull valves out and check
1992 ZX7
1993 ZX950
2003 Zuma 49cc
2006 ZX10R
Couple questions for anyone thats opened a shop xj539 General Discussions 6 09-15-2011 08:53 PM
Brand New Never Opened Speedohealer V4 for 06+ $95 Uncuffed Bikes Parts For Sale 1 08-17-2008 10:52 PM
NEW Never Opened Puig DB Windscreen JRich Bikes Parts For Sale 8 10-03-2007 09:40 AM
track finally opened whynot Drag Race Section 6 07-29-2007 09:23 PM
Online motorcycle mag opened up.... gthmnyt2580 General Discussions 1 03-04-2005 12:15 PM
