Need help with my 2000 r6 : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 12-03-2012, 05:58 PM   #1
rich16
Bike: 2000 yamaha r6
Keeps flooding out so i replaced my float needles an when i turn the key the fuel pump just clicks really loud an pushes gas in the carbs so it still floads out their is a pressure relay in the fuel pump that is makin the noise
rich16 is offline   Reply With Quote
Old 12-03-2012, 07:16 PM   #2
o2r6rider
o2r6rider's Avatar
Bike: '02 R6
My fuel pump clicks til the carb bowls are full too.. What do u mean by "its flooding"? Are the carbs leaking gas?
o2r6rider is offline   Reply With Quote
Old 12-03-2012, 08:23 PM   #3
rich16
Re: Need help with my 2000 r6
Okay if i start the bike let it run for a min turn it off an then try an start it again it wont start but if i unplug the fuel pump it will start so im thinkin their has to be a persure relay somewhere bc if the bowls are already full from it ruing an then the pump is pumpin more gas in the bowls so the gas is just pushin though the shut float needles bc i just replaced those with new ones
Old 12-03-2012, 08:30 PM   #4
Shush319
Big ol pile of them bones
Shush319's Avatar
Bike: 01' CLE R6, 88' GSXR 750
Does the pump run every time you cycle the key? If you turn it on does it stop, then if you cycle it off/on again does it run again? It shouldn't if the bowls are already pressurized.
Shush319 is offline   Reply With Quote
Old 12-03-2012, 10:44 PM   #5
diazannetto
My Sig was removed by a Mod...
diazannetto is offline   Reply With Quote
Old 12-04-2012, 05:22 AM   #6
rich16
Yes the pump will still run even tho the bowls are full
Old 12-04-2012, 05:44 AM   #7
Shush319
Shush319's Avatar
Check the float levels then. If their too high the needles will never cut the fuel flow off.
Old 12-04-2012, 05:55 AM   #8
rich16
Where would i change the float levels or how
Old 12-04-2012, 10:26 AM   #9
Shush319
Shush319's Avatar
The little metal deal the float needle hangs on has to be bent 1 way or another to raise or lower the float height. if you accidentally bent on even the slightest when you changed the float needles, it can change the float height. Its a real pain in the arzzz to get them right too. If you have never done it, I would consult professional help.
Old 12-04-2012, 10:46 AM   #10
rich16
So if i bend them down towards that needle i sould be set
2000 YZF R6 Race Prep - $2000 tsd345 Bikes For Sale 0 05-30-2012 05:43 PM
FS: 2000 - R6 - Black - $2000 - 7000 miles - Michigan somewhere spdrace11 Bikes For Sale 2 08-02-2011 03:03 PM
FS: 2000 - R6 - Champions Edition - $2000 OBO - 30,000 miles - Washington Illernoise Bikes For Sale 14 11-21-2010 09:03 PM
FS: 2000 - R6 - Blue - $2000 - 32,000 miles - Albany, Oregon yotaismygame Bikes For Sale 1 05-21-2010 07:31 PM
