Oil Pan Write up? : Yamaha R6 : R6 Forum
Old 12-03-2012, 06:25 PM   #1
friedshrimp
Bike: 2007 YZF-R6
Oil Pan Write up?
So I attempted change the oil on my R6 for the first time over the weekend and managed to strip the oil pan. I've got a new one with gasket on its way, but I'm looking for a write up for changing the oil pan. My searches haven't really turned much up. If someone can post a link to a write up or make one real quick on this thread, it would be much appreciated.
friedshrimp is offline   Reply With Quote
Old 12-03-2012, 06:40 PM   #2
xzpolskix
scared of big tracks
xzpolskix's Avatar
Bike: 07 track slut
Re: Oil Pan Write up?
I'm going to be of no use on the oil pan write up, but save yourself some time and spend some money on the Stahlbus oil change kit. Well worth the money the next time you do an oil change.
xzpolskix is offline   Reply With Quote
Old 12-03-2012, 06:44 PM   #3
friedshrimp
Bike: 2007 YZF-R6
I've actually already ordered one of those valves. I don't want to deal with a stripped oil pan again. Good suggestions nevertheless.
Old 12-03-2012, 07:17 PM   #4
EL CHE
Libertad
EL CHE's Avatar
Bike: 2006 R6 Raven
I'd would think its pretty straight forward. Remove fairings, remove oil pan bolts, remove oil pan, install new oil pan and gasket (if it requires one), tighten bolts to torque specs, and fill with oil. Lastly check for leaks and reinstall fairings. There are service manuals on here that are in .PDF format which can be downloaded and save for later.
Sent from my Galaxy Nexus using Motorcycle.com Free App
EL CHE is offline   Reply With Quote
Old 12-03-2012, 07:52 PM   #5
shnormo
Got street appeal?
shnormo's Avatar
Bike: '04 and '07 R6
Images: 1
Send a message via AIM to shnormo
1. Remove fairings
2. Drain Oil
3. Remove slip on
4. Remove exhaust headers (with a wobble socket extention you can unbolt the header without removing the radiator)
5. Remove oil pan
6. Remove oil pan gasket with razor and brake clean
7. Reinstall in reverse order of removal
8. Fill back with oil
shnormo is offline   Reply With Quote
Old 12-03-2012, 07:57 PM   #6
Tropicoz
Tropicoz's Avatar
Make sure to clean ALL the gasket material off the motor mating surface. A plastic putty knife and brake cleaner work well to loosen and remove debris. When you're putting on the new gasket, use a good oil resistant sealant like yamabond or Permatex grey and smear a light layer on both sides of the gasket . Tighten bolts to specs in a star pattern. And if you don't already, get a good torque wrench. Not one of those Harbor Fright jobs, but a decent click type....Craftsman can get you by for many years.
Tropicoz is offline   Reply With Quote
Old 12-03-2012, 08:51 PM   #7
Doc-Ram
I ride with Passion
Doc-Ram's Avatar
Bike: 08
Apart from the oil pan drain bolt, everything else needs to be torqued to specs. Its not that hard, but if you have any questions while doing it, post pics and ask on here.
When you remove the pan, take it off slowly to see how everything goes back together. There's a strainer in there that puzzled me for a while.
Doc-Ram is offline   Reply With Quote
Old 12-03-2012, 08:54 PM   #8
pickpocket293
Bike: A slow one.
Yup, it's pretty easy. It's all hex-head bolts.
Don't feel bad, I did the same damn thing a few years ago. Keep the old oil drain plug-- you never know when somebody needs one of those.
pickpocket293 is offline   Reply With Quote
Old 12-03-2012, 08:59 PM   #9
Jdawson2012
Jdawson2012's Avatar
Bike: 2007 R6 Candy Red
^^^This^^^ And honestly its not all that hard, just kind of a PITA. Also as already mentioned that strainer can be kind of a bitch
Jdawson2012 is offline   Reply With Quote
Old 12-03-2012, 10:51 PM   #10
verybigtiter6
verybigtiter6's Avatar
Bike: 2009 r6, 2012 cbr 250
how is the strainer PITA?
verybigtiter6 is offline   Reply With Quote
HID write up Jr1321 Garage / Mechanical Help 1 08-12-2011 03:30 PM
R1 vs 911 GT3 Cool write up slowboyracing General Discussions 4 05-16-2011 03:36 PM
Adding a Gps to a 99-02 (write up) scrnnmssuck Appearance and Exterior Mods 0 07-24-2010 03:31 AM
'00 Oil Change Write Up (If you don't already know.) Paul79UF How To's... 3 05-02-2007 06:06 PM
Check out my write up R6 2006 Off Topic Talk 0 04-22-2007 05:54 PM
