Hoisting 08 R6 using garage rafters : Yamaha R6 : R6 Forum
Old 12-09-2012, 11:49 AM   #1
iHak
iHak's Avatar
Hi there,
Can anyone tell me if there's a way to do this without damaging the bike? I have a lot of work to do on the bike to include suspension work, which requires the bike to have no pressure on the swing arm.
I'd love to just hoist the whole bike up, but am not sure where/how to connect the bike to some sort of hoisting system.. (probably just get ratcheting straps and hoist it to the rafters, but how do I connect to the bike?
Anyone done this?
Thanks!
iHak is online now   Reply With Quote
Old 12-09-2012, 11:54 AM   #2
pickpocket293
Bike: A slow one.
Re: Hoisting 08 R6 using garage rafters
To remove the rear shock I just used two jack-stands on the foot pegs so that the rear wheel is off the ground (and it's even easier if you remove the rear wheel after it's suspended, also). As far as the forks, just get a triple tree stand, or a tall sturdy step ladder and use a ratchet strap like I did here:
http://www.r6-forum.com/forums/showp...9&postcount=27
pickpocket293 is offline   Reply With Quote
Old 12-09-2012, 01:21 PM   #3
Eric10301
Eric10301's Avatar
Bike: 08 R6 Track Bike
If you have all the fairings off you can do it like I did. Buy some soft straps and run them through the frame then connect them to some ratcheting straps.
Eric10301 is offline   Reply With Quote
Old 12-09-2012, 01:35 PM   #4
Tdub
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
If you like working on your bikes, a good set of stands is a good investment.
Tdub is offline   Reply With Quote
Old 12-09-2012, 01:39 PM   #5
MorrowDeath
WOW
MorrowDeath's Avatar
Bike: OH FOUR R599
Should I replace both the lower and upper bearings or will I be fine with just replacing the upper to solve my handle bar play under heavy braking? Just curious cause the lower bearing looks like a lot more work. Plus how did you torque the steering head nut?
"If you put your mind to it, you can accomplish anything"..... Marty McFly
STUFF FOR SALE
MorrowDeath is offline   Reply With Quote
Old 12-09-2012, 01:40 PM   #6
mgossel
Slow edition
mgossel's Avatar
Bike: 08 R6 Yellow
You can buy a set of Craftsman stands at Sears for $20-25. That's what I used when I changed out my rear shock.
mgossel is offline   Reply With Quote
Old 12-09-2012, 01:41 PM   #7
pickpocket293
Bike: A slow one.
Replace the upper and lower..
Old 12-09-2012, 01:47 PM   #8
Tdub
Tdub's Avatar
Bike: Honda Z50
as the lower is the one that takes the beating.
Old 12-09-2012, 01:47 PM   #9
MorrowDeath
WOW
Bike: OH FOUR R599
Is there a write up posted anywhere for the R&R of the steering head bearings?
STUFF FOR SALE
Old 12-09-2012, 01:48 PM   #10
Tdub
Tdub's Avatar
Bike: Honda Z50
Wait for it ........
Garage Mod Potter General Discussions 31 09-11-2010 06:19 PM
Your Garage YZFR62007 General Discussions 109 05-13-2009 07:02 AM
Garage 317 Rider General Discussions 14 08-24-2008 09:28 AM
The best garage frankieg22x General Discussions 0 07-20-2008 11:07 AM
The Dream Garage YZFR62007 Appearance and Exterior Mods 8 07-23-2007 07:51 PM
