2002 R6 Carb Clean : Yamaha R6 : R6 Forum
Old 12-09-2012, 08:21 PM   #1
mdjd
2002 R6 Carb Clean
Hello,
2002 R6 with 10k miles sat for about a year with gas in it. Now it idles rough and maxes out at around 90mph in 6th. I figure the carbs need to be cleaned so I'm doing that, along with replacing the fuel filter and air filter...maybe the spark plugs too.
1. What's the best method to clean the carbs? I'm a little confused...in doing research, some people mention that one doesn't have to completely take apart the carbs. Others say you have to take them completely apart and clean or let soak overnight. How should I proceed? This is where I'm at now:
2. Does one method of cleaning not require to sync the carbs again?
3. I noticed some hard deposits in the hole where the carbs attach to the engine, as seen in the image below. Should I do anything about this?
4. Any other suggestions on maintenance I should do? Already flushed radiator, changed oil, flushed brake lines, lubed chain, new brake pads.
Thank you.
mdjd is offline   Reply With Quote
Old 12-10-2012, 07:12 AM   #2
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
Re: 2002 R6 Carb Clean
At least remove the slide diphragms before spraying cleaners, etc in there or they can disintegrate. I think the 02 thread in signature has pics of when I did it, etc.
REally, you just need to pull the jets, clean em, etc. You also need to clean the bolw and inspect that the float needles aren't sticking, etc. Check float height looks even, etc.
My 02 Thread My 08 Thread
Ask about:-STAHLBUS- -WOODCRAFT- -MOTUL- -FERODO- -BRAKE TECH- -BMC- -Battery Tender-LEO VINCE- -XT-RACING- -NGK- -SUOMY- -EBC- -Pro-Grip- -Canyon Dancer-
Old 12-15-2012, 07:47 PM   #3
mdjd
Thanks for the reply Chief.
I just finished...it didn't seem too dirty/clogged; I've never done it before so I don't really have anything to compare it to though. The main jets all seemed to be unclogged. There were two pilot jets that appeared to have smaller holes (Maybe clogged a bit) inside, but they're already so tiny to begin with so it was hard to tell. After I cleaned those two, they matched the others so we'll see...
Old 12-15-2012, 08:43 PM   #4
mdjd
Haven't ridden it yet, but I just started it...runs so MUCH better!
2000 r6 carb clean help. Where to go from here karlo b Garage / Mechanical Help 12 04-06-2012 05:26 PM
2001-2002 R6 Dynojet Carb Jet Kit billytuffnuts Bikes Parts For Sale 1 08-04-2010 04:10 PM
2002 R6 one carb issue, sometimes.... Flamingtire General Discussions 5 04-14-2010 04:44 PM
Storing a Carb'd Bike (2002 R6) X-SoLjA Garage / Mechanical Help 8 10-15-2009 03:09 PM
New R6 owner...can I clean carb jets without removing carbs? WhyZeeEffAreSix General Discussions 6 03-07-2007 10:03 AM
