(HIDs) Low-beam doesn't always fire : Yamaha R6 : R6 Forum
Old 12-09-2012, 09:18 PM   #1
friedshrimp
Bike: 2007 YZF-R6
So I bought my bike with HIDs installed by a previous owner. My high beam works without fail but my low beam is a different story. Every time I start the bike, the low beam flashes on for a split second. Usually then it goes right back off. Very occasionally will the low beam fire and stay lit when starting the bike. After riding for about 30 minutes, the low beam will usually come on and stay on until I turn the bike off. But if I shut the bike off and then start it right back up, same thing, low beam lights up while starter cranks but won't stay on. Does anyone have an idea what's wrong? Bad ballast? Bad wiring?
friedshrimp is offline   Reply With Quote
Old 12-09-2012, 09:36 PM   #2
Jtronix
Lechon is da Bizness
Jtronix's Avatar
Bike: 2010 R6
Re: (HIDs) Low-beam doesn't always fire
Try swapping the ballast between the high beam and low beam. If the problem switches over to your high beam, then it could be a problem with your ballast. If it doesn't, then continue by swapping your bulbs+wiring harness. If the problem now switches over to your high beam, then could be your bulb/bulb wiring harness. If not, check the wiring upstream to your low beam ballast.
I has a similar situation with my previous bike. Turned out to be a faulty ballast. I replaced it and the problem was solved. Good luck.
Jtronix is offline   Reply With Quote
Old 12-09-2012, 11:55 PM   #3
saleenbiker
My R6 eats Ninjas.
saleenbiker's Avatar
Bike: '07 R6, '07 Ninja 250
I gotta try this. think i might have a faulty ballast too. only on my high beam side
saleenbiker is offline   Reply With Quote
Old 12-10-2012, 07:07 AM   #4
VK56DEHAN
I would slave the bulbs before the ballasts just because you ballasts are probably mounted with 3m tape or something. My low light beam is doing it too. Mine works about 75% of the time. I switched the bulbs out for a couple days and it never failed. Mine is probably a bulb. Yours sounds like a ballast though as it flashes momentarily on start up.
VK56DEHAN is offline   Reply With Quote
Old 12-10-2012, 07:29 AM   #5
natedogg624
You might need a relay harness.
Nathan - #425 - 07 Yamaha R6
35 Motorsports, Vortex Racing, Pit Posse Motorsports, Spy Optics, Suomy Helmets, 614 Paintworx, Optimal Racing, GP Tech
Nationwide Children's Hospital/Ohio Motorcyclists for Children
The Retrofit Source
natedogg624 is offline   Reply With Quote
Old 12-10-2012, 10:02 AM   #6
Agg2001
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
start with this. best way to make sure they're getting the power supply they need. if that doesn't work, then start switching things around.
Agg2001 is offline   Reply With Quote
Old 12-10-2012, 08:29 PM   #7
friedshrimp
Bike: 2007 YZF-R6
Where can I get these parts/is there a certain one I need? I didn't install it so I have no idea what kind of HID kit it is.
High beam vs. Low beam BskooL General Discussions 22 02-11-2012 07:37 AM
Making High Beam look like Low Beam iridetucked Appearance and Exterior Mods 6 09-21-2008 05:33 PM
high beam low beam question scooterroo Appearance and Exterior Mods 4 05-02-2008 05:29 PM
high beam/Low beam, what do you prefer Sh1tmeh General Discussions 14 09-08-2007 09:52 PM
fire fire fire (not my bike) (56k dont bother) alex_kors General Discussions 9 07-07-2006 08:01 PM
