06 track plastics and stock exhaust : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 12-10-2012, 05:26 AM   #1
Dewey
bleed Yami
Dewey's Avatar
Bike: 06 R6(track), 07 R1, 06 Z
Quick question, I was told the track plastics will not fit properly with the stock exhaust (cat), they will sit about an 1" lower. In order to get the proper fit I will need a full exhaust, is this the case?
Dewey is offline   Reply With Quote
Old 12-10-2012, 05:45 AM   #2
cmedrive
roaming gnome
cmedrive's Avatar
Bike: 2008 R6
Re: 06 track plastics and stock exhaust
You don't need to buy a full exhaust, you can keep your headers. You just need to delete the cat. I'm getting a set of track plastics from Anthony at Bauce and I'm having a midpipe welded in to delete the cat. Then I'll pick up a slip on from Anthony as well to complete the exhaust.
I'm using a Ttuners - http://shop.ttuners.com/category.sc?categoryId=3
But there's also MJS - http://shop.mjsperformance.com/categ...1?categoryId=3
cmedrive is offline   Reply With Quote
Old 12-10-2012, 06:01 AM   #3
xzpolskix
scared of big tracks
xzpolskix's Avatar
Bike: 07 track slut
I ended up getting the full system from MJS and sent back all my OEM stuff so it ended up coming out pretty cheap.
xzpolskix is offline   Reply With Quote
Old 12-10-2012, 06:02 AM   #4
narve00
Bike: 07 R6
I run the stock exhaust with Sharkskinz lower. It is an older belly pan, so I'm not sure if that makes a difference.
The biggest problem is heat. I've heat shielded the fairing with aluminum panels. But I still have had things melt, like the kick stand switch and the drain tubes near the oil filter.
narve00 is offline   Reply With Quote
Old 12-10-2012, 07:38 AM   #5
Dewey
bleed Yami
Dewey's Avatar
Is the mid pipe and headers two different pieces? You talk about welding. I have a Yoshi slip-on now, don't want to buy a full system if I can just delete the cat.
Old 12-10-2012, 07:41 AM   #6
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
You cut it into two different pieces. You would be cutting out the muffler in the belly pan and replacing it with the t-tuners pipe.
No need for a full system if you don't want one.
My 02 Thread My 08 Thread Shermoto Racing R6 Levers FREE CLASSIFIEDS!!!!
Ask about:
BMC-Canyon Dancer 2-Motul Specials-Winterization kits/Battery Tenders-LEO VINCE- -STAHLBUS- -WOODCRAFT- -XT-RACING- -FERODO- -BRAKE TECH- -SHERMOTO-
-NGK- -SUOMY- - MOTUL- -EBC- -Pro-Grip-Ohlins and everything else!!
Old 12-10-2012, 09:28 AM   #7
Dewey
bleed Yami
Dewey's Avatar
Thanks for the info guys....always nice to get the answers to save me a few bucks.
08 r6r Plastics, Cluster, and Stock Exhaust CrashDummy2183 Bikes Parts For Sale 5 09-18-2010 08:23 PM
07 r6 stock exhaust/cat with track plastics chase Garage / Mechanical Help 14 03-24-2010 08:30 PM
WTB: 99-02 R6 plastics and stock exhaust bracket squirrel_girl Bikes + Parts + Gear Wanted 3 12-31-2009 03:29 PM
FS:07 R6 Termi exhaust, Stock and Race Plastics TomCat3113 Bikes Parts For Sale 28 06-04-2009 06:17 PM
Quick change from stock plastics to track skins? Jason D Track Tech & Riding Techniques 15 04-29-2009 01:54 PM
