Does it really matter? : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 12-12-2012, 12:45 PM   #1
robthezombie
Giggity
robthezombie's Avatar
Bike: 07 r6 raven
Id like to be able to learn this machine so I understand how it runs and runs most efficintly. So ive been reading around on here about back pressure and how it affects the bike. Im not a mechanic so I dont fully understand the whole issue. So I would like to propose some cases and hear what you think. Does the muffler, honeycomb, or both add to the backpressure?
1. Megaphone exhaust (Hotbodies) with a y-pipe and cats removed.
2. Hotbodies exhaust with y-pipe, but honeycomb still in.
With those two set ups would it be wiser to keep the cat to have some backpressure or does it matter?
I know this exhaust basically has no back pressure so I used it.
I appreciate anyones help trying to figure this out.
robthezombie is offline   Reply With Quote
Old 12-12-2012, 12:57 PM   #2
ridick_bowen
Recreational Stuntrider
ridick_bowen's Avatar
Bike: 03 R6 Stuntbike
Re: Does it really matter?
Buy and powercommander and leave your exhaust alone. Better mod IMO.
Originally Posted by R6_350z View Post
not putting miles on your bike because you want to keep it new is like not having sex with your wife because your saving her for the next guy
ridick_bowen is online now   Reply With Quote
Old 12-12-2012, 02:24 PM   #3
cheefar6
Polish Representative.
cheefar6's Avatar
Bike: 2008 YZF-R6
dont quote me on this, but this 'back pressure' is created by having an exhaust header attached.
If you were to run with your exhaust off, the exhaust gas would be free to exhume into the atmosphere with nothing affecting the flow other then the valve.
when a exhaust is attached, the gasses coming out, must push all of the gasses already filling the exhaust, which creates pressure, like blowing through a straw.
any aftermarket exhaust system will create a small amount of 'back pressure' so your good a ny way you choose to go, although removing the catalytic convertor, will cause the bike to run with incorrect AFR, so fuel management (like the pc3) is recommended.
cheefar6 is offline   Reply With Quote
Old 12-12-2012, 02:39 PM   #4
Eric10301
Eric10301's Avatar
Bike: 08 R6 Track Bike
Just remember if you remove the Cat you will need a fuel controller. If you don't want to buy one that makes the decision easier. Here is all the info you really need http://www.r6-forum.com/forums/showthread.php?t=142421.
Eric10301 is offline   Reply With Quote
Old 12-12-2012, 03:00 PM   #5
robthezombie
Giggity
Bike: 07 r6 raven
OK so if I'm understanding correctly the exhaust( from header to the tip) is what cause the back pressure and the can only affects it a small amount. So having the cat and muffler cause back pressure by causing there to be more pressure to expel the fumes. And that's why a slip on, on this machine is somewhat pointless?
Sent from my SAMSUNG-SGH-I997 using Motorcycle.com Free App
Old 12-12-2012, 03:38 PM   #6
cheefar6
cheefar6's Avatar
Bike: 2008 YZF-R6
the slip on will only change the pitch of the exhaust note, by having different materials/shapes/and amount of sound dampening material (like fiberglass) used in the can.
also the path and size of the exhaust will affect gas flow and sound, unless your racing world class, i wouldnt worry about the "performance gains" company claim to have by running this can with that exhaust, the differences are minimal and difficult to measure correctly.
removing the catalytic convertor lets the engine 'breathe' easier and more efficiently, at the expense of emissions, so just removing the cat will give performance gains, but then going graves and 2bros, or wahtever exhaust you want will be minimal, they are all cat removed.
Old 12-12-2012, 03:42 PM   #7
Ryan5544
Stinks Like Sex In Here..
Ryan5544's Avatar
Bike: GSX-R
Ryan5544 is online now   Reply With Quote
Old 12-12-2012, 04:23 PM   #8
Tdub
FastForward Performance
Tdub's Avatar
Bike: Honda Z50
So in other words, you don't know an answer to his questions...
Tdub is offline   Reply With Quote
Old 12-12-2012, 04:30 PM   #9
Powerstroke87
1*
Powerstroke87's Avatar
Bike: 2007 R6, 2013 DRZ400SM
Originally Posted by Ryan5544 View Post
Fcuking jabronis
-07' Team Yamaha Blue R6 "Carmen"
-08' Nissan Xterra Off-Road "Katrina"
-93' Ford F-150 sitting on 35's "Sandra"
Powerstroke87 is offline   Reply With Quote
Old 12-12-2012, 06:14 PM   #10
robthezombie
Giggity
Bike: 07 r6 raven
OK thanks for the insight. I think Ive got that figured out now. If not for this forum I'd probly ruin my bike doing something some idiot on the street told me to do. I swear noone hear even knows what a powercommander does. They throw on a full system and go. I appreciate everyone who chimed in
??? Does size really matter ??? HardRacing. General Discussions 27 06-26-2012 08:38 PM
Does size matter? bluerebel General Discussions 10 03-12-2012 09:45 AM
Welcome Dark Matter LLC! Admin Dark Matter LLC 6 11-01-2011 01:12 PM
Does Weight Really Matter !!!!!!!!! 1dragracer6 Drag Race Section 3 01-01-2009 07:30 PM
size does matter?.. kafit1612 General Discussions 7 01-13-2008 01:45 AM
