Wire Identification : Yamaha R6 : R6 Forum
Old 12-12-2012, 06:31 PM   #1
Khubs
Wire Identification
Hey guy and gals,
I just picked up an 06 r6 and while I was going through the bike I noticed 2 cut wires. I followed them under the gas tank and they were zip tied together with the o2 sensor and EXUP cables that were also cut. I removed the EXUP cables from the servo motor and also the o2 sensor. (The bike has an aftermarket GYTR full exhaust) They ran up to a brown plug and I have not been able to find anything about what these wires went to. Any help is appreciated.
ID:	87469   Click image for larger version
Khubs is offline   Reply With Quote
Old 12-12-2012, 06:40 PM   #2
brandonduley
R6 Raven
brandonduley's Avatar
Bike: 06 R6 Raven
I think that's the rear brake light wires
2006 R6 Raven:
Yoshimura TRC Full Exhaust (Carbon/Stainless)
Bauce ECU Flash
PCIII
Graves Blocks off
Graves EXUP eliminator
520 Conversion (-1/+2) Driven Sprockets, RK Chain
GIPro Gear Indicator
GP Shift
Rev Limiter Motorcycle Blog
brandonduley is offline   Reply With Quote
Old 12-12-2012, 06:42 PM   #3
brandonduley
R6 Raven
Bike: 06 R6 Raven
Did the PO switch the rear brake switch to a hydraulic switch, meaning connected to the rear brake master cylinder or does your rear brake not activate the light at all?
2006 R6 Raven:
Bauce ECU Flash
PCIII
Graves Blocks off
GP Shift
Old 12-12-2012, 07:11 PM   #4
Khubs
Re: Wire Identification
Yea the rear brake light isnt activated at all by the brake. Man the PO really messed with this bike. I ordered OEM rear sets, and they came with the wires, so that will be fixed. I really appreciate the help. If anyone can post a detailed pic of the OEM right rear set that would be AWESOME.
thanks a lot
Old 12-12-2012, 07:40 PM   #5
brandonduley
R6 Raven
Bike: 06 R6 Raven
Mine only differs from oem due to the brake switch converted to hydraulic from the stock switch that is normally located on the bottom arm of the rearset on the backside. Click image for larger version
Name:	ImageUploadedByMO Free1355369991.749223.jpg
Name:	ImageUploadedByMO Free1355369864.122233.jpg
2006 R6 Raven:
Bauce ECU Flash
PCIII
Graves Blocks off
GP Shift
Old 12-12-2012, 08:55 PM   #6
Khubs
I appreciate it. Thanks for all the info
Old 12-12-2012, 09:58 PM   #7
brandonduley
R6 Raven
Bike: 06 R6 Raven
No problem. Good luck with the bike.
2006 R6 Raven:
Bauce ECU Flash
PCIII
Graves Blocks off
GP Shift
Flushmount identification help. BlkTS02 Appearance and Exterior Mods 5 05-27-2012 07:50 AM
identification help need nummy General Discussions 7 01-05-2012 03:51 PM
Identification wheels peter34 General Discussions 20 12-11-2011 08:21 AM
engine identification NoXi New Member Section 0 02-19-2010 09:19 PM
2006 R6 Identification smktout General Discussions 14 04-16-2006 10:52 PM
