Throttle Won't Snap Back : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 01-06-2013, 09:47 PM   #1
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Bike: 03 R6
Send a message via AIM to CLAWHAMM3R
Hey guys, need help with my sister's (my old) R6...what am I missing here?
2003 R6.
Here's what I've checked:
Bar end is not rubbing the grip/throttle tube.
The decel cable had a lot of slack in it, so I tightened it up, now the throttle doesn't snap back at all lol. This is confusing.
I can disconnect the cables at the throttle bodies, the spring snaps back without the cables in it.
While they're disconnected I can hold each one and pull them back and forth smoothly, freely, and with no binding.
The throttle tube spins freely with the cables disconnected. There was some gunk on the clip on so I cleaned both it and the inside of the throttle tube.
The throttle cables haven't been rerouted or anything like that, since the problem started. I don't know what I'm missing here. Everything works by itself, I hook it all back up and turn the throttle and it stays open.
Any ideas? Very aggravating because it's such a simple set up, yet it's got the best of me at the moment.
Thanks in advance!
2008 R1 | 2004 ///M3
CLAWHAMM3R is offline   Reply With Quote
Old 01-07-2013, 06:14 AM   #2
MELK-MAN
.. the Dude abides..
MELK-MAN's Avatar
Re: Throttle Won't Snap Back
that is not a "decel" cable. The spring on the throttle bodies does that, and is why the throttle should snap back. the 2nd cable is for safety. So you can close the throttle in the event something happens (like the main cable is pinched, spring on tb breaks, etc.).
Put some iree play back in the cables.
MICHELIN, EBC, Silkolene, JenningsGP, Engine Ice, proflow tech
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 01-07-2013, 06:31 AM   #3
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
What Greg said. The fact that there was excessive freeplay in the return cable may be an indication that there was a problem, previously, and someone put slack in the cable as a "band aid" fix. I would concentrate on the return cable.
1.It doesn't need to be taught. Some freeplay is OK
2. Lube the cables. Always a good thing to do.
3. Check the routing. They may feel smooth when disconnected, but when connected, there may be some added stress from a bend that is not present when hanging free. This can also present itself when turning the bars all the way to the left or right.
Dear SpeedTV,
I, for one, will be extremely happy when you finally make the transition to a main line sports channel.
.....it will mark the end of your network pretending to be a motorsports channel.
Thank you for finally realizing what the rest of us already knew.
8Ball is offline   Reply With Quote
Old 01-07-2013, 07:23 AM   #4
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Bike: 03 R6
Thanks guys, now that I think about it it doesn't make sense to tighten that cable unless there's a spring throttle side to pull it back.
I just saw decel cable in the FSM and it was late and my mind wasn't working right.
I'll put the slack back in that cable. And I'll try a different route for the cables even though nothing changed before the start of this issue. Any of ideas?
Old 01-07-2013, 08:25 AM   #5
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
You'd be surprised how much good some lube will do......(slight pause to let the innuendos commence)
Here's the method I use:
1. disconnect the cables from the handle bar end.
2. cut the bottom corner out of a plastic sandwich bag.
3. insert the cable end into the bag from the hole you just cut.
4. wrap a rubber band around the bag and cable housing (making the bag a funnel)
5. spray lube in the bag and let it drain into the cable.
This method, works well and keeps everything fairly clean.
Dear SpeedTV,
Old 01-07-2013, 08:30 AM   #6
lopez95632
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
Pics of sis and we might help more....
must read for new members
lopez95632 is online now   Reply With Quote
Old 01-07-2013, 09:00 AM   #7
NorthShoreR6S
My Power band is blue
NorthShoreR6S's Avatar
Bike: 2009 sold,2008 R6 pink
I need a new sig, Can someone make me one please?
NorthShoreR6S is offline   Reply With Quote
Old 01-07-2013, 09:14 AM   #8
ChiefSmokeDawg
Parts Pimp
ChiefSmokeDawg's Avatar
Bike: 2002 R6, 2008 R6
You do know they sell cable lube kits with the cable too and lube all included?
Something like this, and you spray the lube in thru the tube provided with the bottle of spray aerosol lube
vs.
My 02 Thread My 08 Thread Shermoto Racing R6 Levers FREE CLASSIFIEDS!!!!
Ask about:
BMC-Canyon Dancer 2-Motul Specials-Winterization kits/Battery Tenders-LEO VINCE- -STAHLBUS- -WOODCRAFT- -XT-RACING- -FERODO- -BRAKE TECH- -SHERMOTO-
-NGK- -SUOMY- - MOTUL- -EBC- -Pro-Grip-Ohlins and everything else!!
Old 01-07-2013, 10:27 AM   #9
Pipelinz
Tracers work both ways
Pipelinz's Avatar
Bike: 2006 R6R
vs.
Chief knows all the cool tricks and kit
"If it's stupid but it works, it isn't stupid."
“Out of every one hundred men in battle, ten shouldn't even be there, eighty are just targets, nine are the real fighters, and we are lucky to have them, for they make the battle. Ah, but the one, one is a warrior, and he will bring the others back.” ― Heraclitus
Pipelinz is offline   Reply With Quote
Old 01-07-2013, 10:48 AM   #10
ChiefSmokeDawg
Parts Pimp
Or Chief just knows how to spend money.
But I'd bet that bag full of lube is much less than I use with the tool. You won't see a trained mechanic rigging up a plastic bag mess now would you!? Especially since this is routine, frequent and regular maintenance!
Ask about:
Throttle won't snap back...:( army88m General Discussions 22 07-29-2012 02:31 PM
Throttle sticks, shouldn't it snap back? xxxmph Garage / Mechanical Help 10 05-20-2012 07:01 AM
Throttle doesn't "snap" back after releasing on a 2000 BoostnGTI02 Garage / Mechanical Help 12 02-04-2010 09:28 PM
throttle not snapping back !! help ga705 Garage / Mechanical Help 23 02-26-2008 09:29 AM
Throttle doesn't snap back soul General Discussions 8 07-17-2007 07:20 AM
