HELP!! rattle then engine stopped wth?!?! : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 08-25-2013, 05:48 PM   #1
racer-r6
T.T.T half way
Bike: Yzf R6
racer-r6 is offline   Reply With Quote
Old 08-25-2013, 07:23 PM   #2
MELK-MAN
"The Dude abides .. "
MELK-MAN's Avatar
Re: HELP!! rattle then engine stopped wth?!?!
sounds like your cam chain tensioner failed.. timing may have jumped. The fact your cam chain is lose is a tell-tale sign the cct failed. Timing jumped a little, wont' run. Jumped a lot, the valves are all bent as the pistons hit them.
www.facebook.com/greg.melka.1
My racin n' ridin youtube vids http://www.youtube.com/user/gregmelka?feature=mhee
MELK-MAN is offline   Reply With Quote
Old 08-26-2013, 05:42 PM   #3
racer-r6
T.T.T half way
Bike: Yzf R6
Old 08-26-2013, 06:32 PM   #4
blue03r6
doing your fat girlfriend
blue03r6's Avatar
Bike: 03 R6
Images: 2
yes that's what's happening. the piston is hitting the valves.
if the timing is off 1 tooth it will turn over. I never tried it 2 teeth off.
cct=cam chain tensioner.
you will need to put the timing back in right before you can test the compression of the engine to see if you did in fact bend some valves. that is if the motor will turn over by hand with it in time.
you can pull the tensioner out to inspect it. there is also a pretty expensive guide in there as well. you should replace them both if you have to do one.
anyway, here's a link to the factory service manual. everything you need to know is in it.
http://www.r6messagenet.com/forums/r...ir-manual.html
blue03r6 is offline   Reply With Quote
Old 08-30-2013, 06:07 PM   #5
racer-r6
T.T.T half way
Bike: Yzf R6
Old 08-30-2013, 06:39 PM   #6
HIS OWN 6
Mr. HER6
HIS OWN 6's Avatar
Bike: 08 R6, 97 GSXR, 04 CRF
First, the tensioner is now garbage and needs to be replaced. That is the least of your worries. I don't think there is anything you can do now but pull the head and inspect the damage.
It's not clear weather you have been turning the engine by hand or with the starter, but a sudden stop and freezing is very bad news. Yes, it can still turn when the timing is off a little bit, but when the chain is freely skipping over teeth it will be likely to end up with pistons colliding with valves. At this point you may even have valves that are permanently open because they got bent or some other significant damage like that. You won't know how bad it is until you look inside.
HIS OWN 6 is offline   Reply With Quote
Old 08-31-2013, 07:44 PM   #7
racer-r6
T.T.T half way
Bike: Yzf R6
Old 08-31-2013, 07:45 PM   #8
racer-r6
T.T.T half way
Bike: Yzf R6
Old 08-31-2013, 08:36 PM   #9
8Ball
UR B-hind Da 8 Ball
8Ball's Avatar
Bike: '03 R6, XR400, V-Star
Those valves are bent. They have hit the piston and can't close all the way. This leaves the shim buckets (Followers, as you called them) with a lot of clearance to just bounce around. See attached:
8Ball is offline   Reply With Quote
Old 09-03-2013, 07:46 AM   #10
4b316
Pull the head is next step.post some pics
4b316 is offline   Reply With Quote
2000 5eb engine running then stopped Jay762 Garage / Mechanical Help 5 06-28-2013 08:08 AM
Engine knock/rattle, help? |/3|\|0|\/| Garage / Mechanical Help 22 04-26-2013 03:04 PM
2006/07 r6 engine rattle h7thl General Discussions 2 07-30-2012 09:14 AM
electrical engine rattle mac8084 Garage / Mechanical Help 1 07-15-2011 06:06 PM
2007 R6 Engine rattle? Mark Garage / Mechanical Help 8 04-13-2007 06:58 PM
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
