Well once you have the side caps off, move that visor all the way to the top then slide the clear tab all the way to the right to remove the visor. Install new one the same way. That tab squeezes these 2 plastic pieces that hold the visor in place.
To install the side pod back on, hook it up to the upper slot and hold it flush to the helmet, use the key to push in the tab and apply some force towards the front portion of the side pod. You should hear a click once it's mounted.
