Ohlins Q. --- top mount type : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 05-23-2006, 11:05 PM   #1
Firedog
My R6 ate yours.
Bike: 2002 R6
Images: 2
Ohlins Damper Question --- top mount type
I just bought a New Ohlins damper for my 2002 R6. My question/concer is the steering stem nut. In the direction's it refers to "use the nut provided" but there was no nut. Did i get jacked or am i supposed to reuse the stocker?
Im not sure what to think because in the "note" paragraph for,the above, it also says to NOT use the washer that was with the nut. Suggesting the stock one.
Using the stock nut; im only able to enguage 3/4's of the threads on the nut. Is this enough? Thanks for all replays!!
side note: can someone send me the thread link for a "how to post pics". I looked and had no luck.
Firedog is offline   Reply With Quote
Old 05-24-2006, 01:31 AM   #2
Demon46
Got Speed?
Demon46's Avatar
Bike: 06 YZF-R6, 03 CBR600RR
I'm not sure if the mounting hardware for the '02 is anything like the '06, but I know the '06 definitely does not use the stock steering stem nut.
The mounting hardware with the Ohlins kit (for the '06), has it's own steering stem nut built into the piece that connects to the front tank bolt to hold the bracket for the damper itself.
Again, the '02 mounting hardware could be completely different, so this may not be very useful, but here's a pic in case it helps at all:
Do you have an actual Ohlins kit (includes the Ohlins mounting hardware), or an Ohlins damper with aftermarket mounting hardware? The Ohlins kit should have very clear instructions on which stock hardware to keep and where to use the Ohlins components.
Demon46
BIKES
2006 Yamaha YZF-R6 (raven black) - Ohlins steering damper / High-Concept frame sliders / Ride Engineering fender eliminator / Clear Alternatives integrated tail light (clear) / HotBodies clear LED flushmounts / Puig dark smoke windscreen / GTYR solo seat cowl / MCarbon carbon fiber tank cover / Lockhart Phillips swingarm spools (black) / MCarbon carbon fiber tank side covers / MCarbon carbon fiber front fender / MCarbon carbon fiber faring inserts / MCarbon carbon fiber rear hugger / MCarbon carbon fiber chain guard / GTYR passenger peg plugs / SportBikeCam camcorder mount / GTYR carbon fiber tank pad / Michelin Pilot Power 2CTs
2003 Honda CBR600RR (red) - ProGrip clear tank pad / Lockhart Phillips swingarm spools
CAGE
2005 Subaru WRX Sti (WRC blue) - short-throw shifter / titanium shift knob / OEM turbo boost guage
Demon46 is offline   Reply With Quote
Old 05-24-2006, 01:38 PM   #3
Firedog
My R6 ate yours.
Bike: 2002 R6
Images: 2
Hey thanks for the response.
It's similar but too different to tell if i should have had a nut. Im going to go back into Cycle Gear today and see WTF's up. The nut they provided for you was it just slimmer? still aluminum right?
Old 05-25-2006, 02:07 AM   #4
Demon46
Got Speed?
Demon46's Avatar
Not exactly - The steering stem nut that was on there originally was open at the top, so you could actually see into the steering stem with it on. The Ohlins mounting hardware doesn't include an actual stand-alone nut at all - It's a bit tricky to see in the picture, but if you look under the damper where the steer stem is, you'll see the nut from the Ohlins mounting piece. But it's actually all one piece with that entire mounting bracket behind it. The nut the tightens over the steering stem is set into a ball-bearing swivel, which is all one piece with the mounting bracket the mounts to the tank bolt in the front and the swivel clamp for the damper (if that makes sense at all? )
I'd definitely check with the people you bought it from first. Thats one part of the bike that I wouldn't even want to take the chance of something going wrong with.
Good luck with it - I don't know that I can be of much help, but if you have any questions, just give me a holler and I'll do my best.
Demon46
BIKES
CAGE
Old 05-25-2006, 12:34 PM   #5
Firedog
My R6 ate yours.
Bike: 2002 R6
Images: 2
ya i t makes sence. I was wondering how you were picking up the extra swivle for the damper movement, and figured that was how.
How do i post a pic so i can show you what my kit looks like.
thanks again
BSI Standard - helmets method62 Safety Equipment 3 11-18-2005 01:28 AM
03 Ohlins with graves mount installing-how? ptirmal Garage / Mechanical Help 0 08-08-2005 06:03 PM
ohlins damper mount location churning Suspension settings 0 03-15-2005 09:37 PM
Two Bros Sale flatout Site Sponsored Specials 0 01-13-2005 09:22 AM
top mount ohlins damper Aldebaran General Discussions 3 01-08-2005 11:01 PM
