2007 Yamaha R6 full bodyworks Set with Tank : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > The Marketplace > Bikes Parts For Sale
Old 12-13-2006, 09:27 AM   #1
Joseph
2006 Yamaha R6 full bodyworks Set with Tank
This is a 2006 Yamaha R6 Blue bodywork Set (will fit 2007 also). It has 900 miles and has never been down, Not one mark anywhere.. Set comes with everything you see in pics, full upper, windscreen, headlight, headlight wire, fender, both lowers, all side fairings, Tank, tank covers ram air tube, mirrors, tail and undertail, fuel pump, NO GAS CAP. $1,200. shipped in US only will not seperate
email me at PEARSON627@YAHOO.COM NO PMs
OR CALL AT 832-216-1058 Joseph
I also have full Forks set, subframe, GPR damper, 03-04 R6 rims
Joseph is offline   Reply With Quote
Old 12-13-2006, 11:44 AM   #2
southern118
r1-***** postwhore
Bike: 06r6/2000 cbr f4
Images: 1
Re: 2007 Yamaha R6 full bodyworks Set with Tank
im sorry that is not 07 body work that would be 06 body work. the stickers are all wrong for the 07
southern118 is offline   Reply With Quote
Old 12-13-2006, 01:26 PM   #3
jbigelow
jbigelow's Avatar
where are you located?
06 R6 ANNIVERSARY EDITION:
* RIZOMA fender eliminator, grips, bar ends, rear sets
* FABBRI solo pista clear windscreen
* PAZZO shorty levers
* TERMIGNONI slip-on
* CLEAR ALTERNATIVES integrated taillight
* PROTON flushmount signals
* GYTR cf tank pad
* STOMP grips
jbigelow is offline   Reply With Quote
Old 12-13-2006, 01:32 PM   #4
Joseph
Houston TX
Old 12-13-2006, 06:55 PM   #5
Yamahauler
I'm To Sexy For My Raven
Yamahauler's Avatar
Bike: 2006 R6 Raven
Images: 1
Not to knock you are anything because everyone I see selling body work doe's the same thing, but what makes people just lay the plastics and the tank on the cement without any protective cover underneath?
I know you probably were very careful when placing the plastics on the ground, but why not just lay a sheet underneath first?
Performance Modifications:
*DID ERV3 X-Ring Chain 520 Pitch *Driven Front Sprocket (black) 15 tooth 520 Pitch *Driven Rear Sprocket (black) 47 tooth 520 Pitch *Driven Grip D637TH *Dynojet Ignition Module *Dynojet Power Commander III USB *GP Shift Pattern *Graves Motorsports Smog Block Off Plates *GYT-R Performance High Flow Air Filter *Hyperpro RSC Steering Damper (Raven brackets) *LeoVince SBK Factory EVOll Full System, Carbon with Carbon End Cap with Quite Insert (removed) *Pazzo Racing Levers (shorty, black with gold adjusters) *SpeedoHealer Calibrator v3.0 *Spiegler Stainless Steel Front and Rear Brake Lines (black lines, black banjos) *Spiegler Banjo Bolts (black)*
Bling Modifications:
*Clear Alternatives Integrated Tail Light *GoldenEye HID Kit, 6000K Headlight, 3000K Highbeam *Gregg's Customs Flushmount Signals *GYT-R Carbon Tank Pad *GYT-R Frame Sliders (no-cut) *GYT-R Passenger Peg Plugs *GYT-R Seat Cowl *GYT-R Swing Arm Spools (black) *LawstCaws Frame Plugs *MotoMummy Fire Reservoir Sock *Pilot LED Center Running Light *Powder Coated Rearsets and Side Stand (Raven Black) *Puig Double Bubble Racing Screen (dark smoke) *SKUR Custom Carbon Fiber Top Clamp Cover *VFX Pivot Kit Plate Bracket with LED MicroStrip Plate Light *VFX Running Light FX Kit *VFX Universal Flasher Relay *Yamaha European Ignition Key *Yamaha Tuning Fork, Aluminum Brake Reservoir Cover (black)*
Its heaven and hell here, which one will I live today?
Yamahauler is offline   Reply With Quote
Old 12-13-2006, 07:19 PM   #6
twenty07surf
2006 R6
twenty07surf's Avatar
Bike: 2006 R6
Images: 2
Who did you steel the plastics from?
twenty07surf is offline   Reply With Quote
Old 12-13-2006, 07:37 PM   #7
Az 05 R6
Take it to the Track
Az 05 R6's Avatar
Bike: 2006 Blue Yamaha YZF R6
Send a message via MSN to Az 05 R6 Send a message via Yahoo to Az 05 R6
^^^^ hahahahhaha
2005 Blue Yamaha R6: TOTALED!
2006 Blue Yamaha R6:
Want to see more pics? CLICK HERE
Want to hear two bro's exhaust sound clip? CLICK HERE
Hi concept frame and clutch sliders
Galfer Blue SS Brake Lines
Vortex Adj. Rearsets
Hyperpro Steering Damper
Pazzo Black Shorty Race Levers w/ Blue Adjustors
PCIIIUSB
Two Brothers Carbon Fiber Exhaust
Integrated tail light
Front Flush Mounts w/ transistor,
Puig DB Dark Smoke Windscreen
Vortex 520 -1/+2 w/ blue sprocket and chain
Anodized Blue Half Cut Passanger Foot Pegs
Speedo Healer
Custom Fender Eliminator
Blue/Black Gel Grips
Braking Wave Rotors
EBC Cintered Brake Pads
Cheata Fiber Glass Body Work
SDC Custom Paint-- Thanks Matt
Az 05 R6 is offline   Reply With Quote
Old 12-13-2006, 07:40 PM   #8
Joseph
I race for CMRA my name is Joseph Mccamish check me out under Team Penetration, I have this stuff from my race bike.. and left over parts
Old 12-13-2006, 08:03 PM   #9
southern118
r1-***** postwhore
Images: 1
but i have to say you havent said anything about it being 06 plastics
Old 12-13-2006, 08:24 PM   #10
Joseph
yes they are 06, I edited it already..
Reason ENOUGH to keep your 2006 R6.. Daekwan General Discussions 71 12-25-2006 03:16 PM
2007 Yamaha R6 Full Forks Set Joseph Bikes Parts For Sale 2 12-14-2006 06:58 AM
2006 Yamaha R6 Subframe MINT Joseph Bikes Parts For Sale 1 12-13-2006 12:57 PM
Revied my lettter for offer to buy back 2006 r6 from Yamaha jrock7896 General Discussions 42 02-15-2006 12:28 AM
06 R6..Bad tank slap at 140mph HamsterZ General Discussions 30 02-07-2006 04:01 AM
