R6 Service Manual Fault Code Table : Yamaha R6 : R6 Forum
Old 07-02-2007, 03:33 PM   #1
pnrfame
11 - No normal signals are received from the cylinder identification sensor when the engine is started or while the vehicle is being driven.
12 - No normal signals are received from the cranshaft position sensor.
13 - Intake air pressure sensor: open or short circuit detected.
14 - Intake air pressure sensor: hose system malfunction (clogged or detached hose.)
15 - Throttle position sensor (for throttle valves): open or short circuit detected. Throttle position sensor (for throttle valves) coupler connection is loose.
17 - EXUP servo motor circuit: open or short circuit detected or loose connection.
18 - EXUP servo motor is stuck.
19 - Open circuit is detected in the input lead from the sidestand switch to the ECU.
20 - When the main switch is turned to "ON", the atmospheric pressure sensor voltage and intake air pressure sensor voltage differ greatly.
21 - Coolant temperature sensor: open or short circuit detected.
22 - Air temperature sensor: open or short circuit detected.
23 - Atmospheric pressure sensor: open or short circuit detected.
24 - No normal signal is received from the o2 sensor.
30 - Latch up detected. No normal signal is received from teh lean angle sensor.
33 - Open circuit detected in the primary lead of the cylinder #1 ignition coil.
34 - Open circuit detected in the primary lead of the cylinder #2 ignition coil.
35 - Open circuit detected in the primary lead of the cylinder #3 ignition coil.
36 - Open circuit detected in the primary lead of the cylinder #4 ignition coil.
39 - Open ciruit detected in a primary injector.
40 - Open circuit detected in a secondary injector.
41 - Lean angle sensor: open or short circuit detected.
42 - No normal signals are received from the speed sensor.
- Neutral switch: open or short circuit detected.
43 - Power supply to the injectors and the fuel pump is not normal.
44 - An error is detected while reading or writing on EE-PROM (CO adjustment value).
46 - Power supply is not normal.
50 - Faulty ECU memory. (When this malfunction is detected in teh ECU, the fault code number might not appear on the meter.)
59 - Throttle position sensor (for throttle cable pulley): open or short circuit detected. Throttle position sensor (for throttle cable pulley) coupler connection is loose.
60 - Throttle servo motor: open or short circuit detected. Defective throttle servo motor. Malfunction in ECU (servo motor driving system).
Er-1 - No signals are received from the ECU.
Er-2 - No signals are received from the ECU within the specified duration.
Er-3 - Data from teh ECU cannot be received correctly.
Er-4 - Non-registered data has been received from the meter.
there they all are. When something goes wrong with your bike and the fault number flashes across the lcd, you should find what you're looking for here. I know this is a large post, but I had to do it. For all those out there that need help, or would like to have a copy of the service manuals, you can find them here.
2007 Yamaha R6
http://www.r6messagenet.com/forums/p...R6_Service.pdf
Peace
Love
and chicken grease.
pnrfame is offline   Reply With Quote
Old 01-27-2009, 02:09 PM   #2
Jeremy03R6
Jeremy
Jeremy03R6's Avatar
Bike: 03 yamaha R6
Re: R6 Service Manual Fault Code Table
THANK YOU!!!! so much...now do you know how to delete them? lol
Texas born and raised.
Jeremy03R6 is offline   Reply With Quote
Old 02-11-2009, 11:08 AM   #3
heavyhitter121
Ain't nothin sweet
Bike: 03 R6
so what are 1-10? i know they are adjustments, but do you have any idea where i would find out what each individual one does(couldnt find anything in the service manual, but just gave it a skim so perhaps i missed it?)?
heavyhitter121 is offline   Reply With Quote
Old 03-12-2009, 07:37 PM   #4
B-Hob
07 r6 is rippin
B-Hob's Avatar
Bike: 07 r6 charcole and black
Images: 1
Send a message via AIM to B-Hob
anyone no how much of a pain code 18 is to fix
B-Hob #15 www.springfieldwolfpack.com
B-Hob is offline   Reply With Quote
Old 08-28-2009, 07:24 AM   #5
aaron07r6
anybody have a clue how to fix code 30...lean angle??
aaron07r6 is offline   Reply With Quote
Old 09-28-2009, 05:11 PM   #6
Agg2001
Original Member-Vendor
Agg2001's Avatar
Bike: 2007 R6, 2005 CRF250r
sweet! bump for this find thanks to google.
Agg2001 is offline   Reply With Quote
Old 09-28-2009, 05:13 PM   #7
Doc-Ram
I ride with Passion
Doc-Ram's Avatar
Bike: 08
Mods, pleez sticky this thread!!!
Doc-Ram is offline   Reply With Quote
Old 09-28-2009, 05:34 PM   #8
Mario J
RESPECT Welcome committee
Mario J's Avatar
Bike: 2013 GRB STI
Images: 3
+1231526547658769
XBL/PSN Gamertag: Mezkinman
Originally Posted by trevor304 View Post
guy martin.... is he a stunter?
Originally Posted by BlanksR6 View Post
humbolt county is near fresno, sure thats NORCAL
RIP Jason Jones (Snocompton)
Mario J is offline   Reply With Quote
Old 01-19-2011, 09:31 PM   #9
lopez95632
candy red
lopez95632's Avatar
Bike: 07 r6s
Send a message via MSN to lopez95632
I'm getting 32... Any help?
must read for new members
lopez95632 is offline   Reply With Quote
Old 08-01-2011, 07:30 PM   #10
3742tb
how to read the codes
3742tb is offline   Reply With Quote
06 r6 Trouble code 12 "HELP"! Joshua Gomez Sr. Garage / Mechanical Help 20 02-15-2007 02:46 PM
2004 YZF-R6 Service Manual in PDF inspectorscott General Discussions 16 01-28-2006 06:26 AM
service and electrical manual pascal General Discussions 3 09-03-2004 07:21 PM
R6 Service Manual and Diagnostic codes. TexasR6 Garage / Mechanical Help 0 08-11-2004 09:18 PM
service manual help opening 03r6sbk The Computer Guru Section 2 05-23-2004 05:06 PM
