Bad Coil Packs : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Community Topics > General Discussions
Old 08-02-2007, 07:36 PM   #1
400whpVW
I wanna go FAST !
Bike: '04 R6
Bad Coil Packs
Hey guys, I'm having stumbling issues with my bike. I'm thinking its the coil packs. The bike does have the newer mitsu coils. My question is, is there any visual way to confirm the coil packs are bad ? Some sort of discoloration on them ?
All of my coils seem to have this spot of discoloration on them.
...do you guys think I should just go ahead and replace them ?
400whpVW is offline   Reply With Quote
Old 08-03-2007, 12:37 AM   #2
McCraZzYY
I spank my R6
McCraZzYY's Avatar
Bike: '03 R6
Re: Bad Coil Packs
not sure if i know the complete answer for you since i cant see the whole coil. however i just got mine replaced on my '03 (the year there was a recall on them) anyhow so you can see in the ATTACHED pics that there is a burn mark around the entire coil....also if you look closely you can see some damage foam where the current was arcing to the cylinder head!!!!!
i am going to do a complete write up sometime soon when i get the chance so people can see this, but hope this helps....let me know
Originally Posted by fyrefyter0143
the R6 is like a drunkin prom date...it can be taught to do anything
Damn bitch you stupid fly lemme pull up to yo bumper an smack dat monkey
McCraZzYY is offline   Reply With Quote
Old 08-03-2007, 12:38 AM   #3
McCraZzYY
I spank my R6
McCraZzYY's Avatar
Bike: '03 R6
Re: Bad Coil Packs
btw just so you understand...the top color doesnt matter, what you want to look at is the metal in the middle....
Old 08-03-2007, 03:36 AM   #4
400whpVW
I wanna go FAST !
Bike: '04 R6
Re: Bad Coil Packs
Ya none of the coils have any burn marks like in the pics you provided. Although I did check the resistance on the coils, and the primary resistance on all 4 is not with in check, but the secondary resistance on all coils seems to be fine.
Old 08-03-2007, 07:05 AM   #5
McCraZzYY
I spank my R6
McCraZzYY's Avatar
Bike: '03 R6
Re: Bad Coil Packs
hmm well there is still a chance there is something wrong internally....if you are having 'stumbling' issues then you are probably misfiring in one or all the cylinders at some point, the most likely problems could be your spark plugs or your coils.....or BOTH i would just replace all of those and see where that gets you...
Old 08-03-2007, 10:35 AM   #6
R6girl74
I ride it like I stole it
Bike: 03' R6
Images: 5
Re: Bad Coil Packs
If you change the plugs make sure to check the gap, even if the guy in the store says there pregaped. Measure them yourself. I've gotten plugs and the guy in the store said there all good and when I got home the gap was way off. If the gap is not right the bike won't run right. Plus make sure the coil pak/ plug boot is all the way in and is seated right. Other than don't dunno.
R6girl74 is offline   Reply With Quote
Ign. Coil Removal 06? ussoldierforhire Garage / Mechanical Help 1 04-01-2007 02:22 AM
Ignition coil and sprocket retaining nut RONs03r6 Garage / Mechanical Help 5 01-16-2007 06:30 PM
Bad coil wires on nos 2003 Garage / Mechanical Help 1 09-10-2006 08:09 AM
2003 Coil Packs njk27 Exhaust and fuel delivery 8 02-08-2005 10:26 PM
2002 R6, #4 exhaust pipe cold, coil is ok...why not firing dragonm Exhaust and fuel delivery 5 12-02-2004 10:30 AM
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
