blinkers : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Appearance and Exterior Mods
Old 09-11-2007, 02:18 PM   #1
jdowens
Bike: 2002 r6
blinkers
my turn signal light is staying on and some times it flashes on and off and my blinker light on the left front is out which is why im guessing its staying on right? how to change it? also if the blinker light is staying on but if you hit a hard bump or something it will flash or go off then come back on a few mins later then to me that would be a short in the wiring?
jdowens is offline   Reply With Quote
Old 09-12-2007, 11:53 AM   #2
jdowens
Bike: 2002 r6
Re: blinkers
anyone know anything
Old 09-13-2007, 03:26 PM   #3
mmiguy2698
Re: blinkers
The way you decribe it it seems as if you have a short, where not sure. To find it hook up your multi-meter to the frame and the other end to each individual wire going into the signal, if nothing the go to the fuse box and test the wires from there to the signal checking each for continuity.......
mmiguy2698 is offline   Reply With Quote
Old 09-13-2007, 04:45 PM   #4
bakaster
I drank what?......
bakaster's Avatar
Bike: 2004 liquid silver r6
Re: blinkers
having one of your lights out usually make the blinker on the same side blink faster seeing that it is under a smaller load rather than staying on
"abandon all hope ye who enter here"
-Dante
A good ride is one you can walk away from, a great ride is one where your bike still works afterwards
bakaster is offline   Reply With Quote
Old 09-13-2007, 08:37 PM   #5
jdowens
Bike: 2002 r6
Re: blinkers
so what would make it come on and stay on? a short?
Old 09-14-2007, 07:47 AM   #6
bakaster
I drank what?......
bakaster's Avatar
Re: blinkers
possibly, maybe a poorly connected capacitor? not entirely sure
-Dante
Old 09-14-2007, 07:52 AM   #7
ACCLR8
Moderatore Eccellente!
ACCLR8's Avatar
Bike: YAMAHA
Re: blinkers
Most turn signal relays are amp driven, and if ther isn't enough draw on it it will stay on, and if the is too much it will blink really fast. Replace your bulb, and problem solved.
Click on my signature to see pics and updates on Isabella , our youngest forum member, born 11/6/2007
ACCLR8 is offline   Reply With Quote
Old 09-14-2007, 07:52 PM   #8
jdowens
Bike: 2002 r6
Re: blinkers
how do i change it
Old 09-14-2007, 11:38 PM   #9
Speedfreak_x77
DallasKrew.com
Speedfreak_x77's Avatar
Bike: 05, R6
Re: blinkers
to change the bulb there should be screw to remove on the bottom. this will help seperate the housing from the glass piece. THen simply remove the bulb , replace with a new one and close.
Speedfreak_x77 is offline   Reply With Quote
Old 09-15-2007, 11:09 AM   #10
jdowens
Bike: 2002 r6
Re: blinkers
i changed it and it wouldnt light it? i think theres some corrosin on the conections because i could never get it to light up the bulb but i touhed it with a srew driver and it sparked what should i do?
HTML code is On
bike question?? need help with dang blinkers jasontylers General Discussions 2 05-23-2010 05:25 PM
PROBLEM: Both blinkers and blinking fast animalmother85 General Discussions 13 08-03-2007 05:32 AM
Just bought an '01 No front blinkers and back blinkers arent wired? Sal'sR6 Appearance and Exterior Mods 4 07-20-2007 08:11 AM
rear running blinkers mod jeff_o Appearance and Exterior Mods 8 06-09-2007 10:21 AM
Does an R6 have rear blinkers? picass1850 General Discussions 30 04-15-2005 02:57 PM
