what is the most brightest? 4000k or 6k? coz im planning to buy HID for my R6 06, and i want the brightest.. even if it is blue, as long as it is much brighter than the 4k or all other, then ill go for the 6k... i need your opinion guys...
and how much did u get it? im on vacation here in texas and ill be going back to the philippines on dec...
i dont know any shops here coz im not from around here.. i live in paris texas
well 8k is technically the brightest, but the higher on the k scale you go, the less actual light output you have. 6k is typically a pretty good balance between light output and the blue color that people want out of their hid's
Life is good......at 16,000rpms
The average person burns 19 calories giving the finger....burn away
No, 8K is not as bright as the 6K, its just adds more color to the bulb.
Performance Modifications:
*DID ERV3 X-Ring Chain 520 Pitch *Driven Front Sprocket (black) 15 tooth 520 Pitch *Driven Rear Sprocket (black) 47 tooth 520 Pitch *Driven Grip D637TH *Dynojet Ignition Module *Dynojet Power Commander III USB *GP Shift Pattern *Graves Motorsports Smog Block Off Plates *GYT-R Performance High Flow Air Filter *Hyperpro RSC Steering Damper (Raven brackets) *LeoVince SBK Factory EVOll Full System, Carbon with Carbon End Cap with Quite Insert (removed) *Pazzo Racing Levers (shorty, black with gold adjusters) *SpeedoHealer Calibrator v3.0 *Spiegler Stainless Steel Front and Rear Brake Lines (black lines, black banjos) *Spiegler Banjo Bolts (black)*
Bling Modifications:
*Clear Alternatives Integrated Tail Light *GoldenEye HID Kit, 6000K Headlight, 3000K Highbeam *Gregg's Customs Flushmount Signals *GYT-R Carbon Tank Pad *GYT-R Frame Sliders (no-cut) *GYT-R Passenger Peg Plugs *GYT-R Seat Cowl *GYT-R Swing Arm Spools (black) *LawstCaws Frame Plugs *MotoMummy Fire Reservoir Sock *Pilot LED Center Running Light *Powder Coated Rearsets and Side Stand (Raven Black) *Puig Double Bubble Racing Screen (dark smoke) *SKUR Custom Carbon Fiber Top Clamp Cover *VFX Pivot Kit Plate Bracket with LED MicroStrip Plate Light *VFX Running Light FX Kit *VFX Universal Flasher Relay *Yamaha European Ignition Key *Yamaha Tuning Fork, Aluminum Brake Reservoir Cover (black)*
Its heaven and hell here, which one will I live today?
Color Temperature is a measurement in Degrees Kelvin that indicates the hue of a specific type of light source. Many people believe the misconception that colour temperature is a rating of the brightness of the bulb or HID kit. This belief is completely false. The reality of the matter is that the higher the colour temperature, the less useable light output you will obtain. A perfect example would be a black light. This light has a colour temperature of approx 12,000k and has almost no useable light or lumens output. Higher K kits such as 7000k, 7500k, etc. have been manufactured for individuals that are more concerned about the actual colour output of their lights as opposed to the actual useable light output they produce.
