Electrical LED Question : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Appearance and Exterior Mods
Old 12-24-2007, 08:44 AM   #1
cdickgo
Vrooom on a Yamaha
cdickgo's Avatar
Bike: 2007 YZFR6
I have an '07 R6 and installed a Clear Alternatives integrated tail light about a month ago. The blinkers did the fast flash thing so I wired in the included resistors and they went back to the stock flashing speed. Yesterday I installed a set of LED flushies to replace the stock front blinkers. The blinkers went to the fast flash again so I went to cycle gear and bought this load equalizer. I replaced the stock box with the new one and I am back to the stock flash speed again.
My question is, since I replaced the stock flashing module, can I remove the resistors for the rear tail light or does this only affect the front blinkers. The only reason I ask is because the resistors heat up when the blinkers are on and I'd like to remove them if I can. It is kind of a good thing because I never forget to turn of my blinkers, because I think about them heating up when they are on, but I really don't want to worry about them anymore.
This is what I installed (under the tank in front of the battery)
http://www.cyclegear.com/lpgm.cfm?L1...tem=MRX_FRH1_G
cdickgo is offline   Reply With Quote
Old 12-24-2007, 09:19 AM   #2
hector113
MACGYVER 05 R6 NJ
hector113's Avatar
Re: Electrical LED Question
Yes you should take out the resistors. The left blinkers and right blinkers are wired together like a car. When one blows out they blink fast. That is why when you installed the leds the blinked fast.
hector113 is offline   Reply With Quote
Old 12-24-2007, 10:40 AM   #3
cdickgo
Vrooom on a Yamaha
cdickgo's Avatar
Bike: 2007 YZFR6
Cool. Solved my dilemma. Thanks.
HTML code is On
Household electrical question. focalf5 Off Topic Talk 1 02-20-2007 04:06 AM
06 r6 electrical noise yakuza General Discussions 20 10-02-2006 01:24 PM
a simple question? vikingar Exhaust and fuel delivery 0 09-07-2006 04:03 PM
Electrical question....garage door remote..... ddayton217 How To's... 3 03-01-2005 10:14 PM
Electrical Woes Fireblader Garage / Mechanical Help 3 02-08-2004 04:53 PM
