Question about Micron slip on : Yamaha R6 : R6 Forum
Old 01-21-2008, 02:06 PM   #1
jayj024
Bike: 2000 R6
This may be a bit of a newb question, but that's what I am when it comes to this stuff.
My 2000 R6 currently has a D&D slip on installed and I just bought a Micron slip on to replace it. My question is, can I just switch the cannisters, or is it necessary to replace the midpipe that's currently on the bike with the one that came with the Micron? Thanks.
jayj024 is offline   Reply With Quote
Old 01-21-2008, 04:23 PM   #2
Skeeter
Forum Moderator
Skeeter's Avatar
Bike: '03 Sliver R1'06 Raven R6
Images: 3
Re: Question about Micron slip on
I would use the one Micron supplied. There could be fitment issues you can't see if you keep the old one on.
Skeeter is offline   Reply With Quote
Old 01-21-2008, 04:49 PM   #3
R6S in Daygo
what?
R6S in Daygo's Avatar
Bike: 07 R6S,
Send a message via Yahoo to R6S in Daygo
+1 ^
R6S in Daygo is offline   Reply With Quote
Old 01-21-2008, 06:12 PM   #4
Yamahauler
I'm To Sexy For My Raven
Yamahauler's Avatar
Bike: 2006 R6 Raven
Images: 1
I doubt that the Micron exhaust will even fit on the D&D midpipe.
Performance Modifications:
*DID ERV3 X-Ring Chain 520 Pitch *Driven Front Sprocket (black) 15 tooth 520 Pitch *Driven Rear Sprocket (black) 47 tooth 520 Pitch *Driven Grip D637TH *Dynojet Ignition Module *Dynojet Power Commander III USB *GP Shift Pattern *Graves Motorsports Smog Block Off Plates *GYT-R Performance High Flow Air Filter *Hyperpro RSC Steering Damper (Raven brackets) *LeoVince SBK Factory EVOll Full System, Carbon with Carbon End Cap with Quite Insert (removed) *Pazzo Racing Levers (shorty, black with gold adjusters) *SpeedoHealer Calibrator v3.0 *Spiegler Stainless Steel Front and Rear Brake Lines (black lines, black banjos) *Spiegler Banjo Bolts (black)*
Bling Modifications:
*Clear Alternatives Integrated Tail Light *GoldenEye HID Kit, 6000K Headlight, 3000K Highbeam *Gregg's Customs Flushmount Signals *GYT-R Carbon Tank Pad *GYT-R Frame Sliders (no-cut) *GYT-R Passenger Peg Plugs *GYT-R Seat Cowl *GYT-R Swing Arm Spools (black) *LawstCaws Frame Plugs *MotoMummy Fire Reservoir Sock *Pilot LED Center Running Light *Powder Coated Rearsets and Side Stand (Raven Black) *Puig Double Bubble Racing Screen (dark smoke) *SKUR Custom Carbon Fiber Top Clamp Cover *VFX Pivot Kit Plate Bracket with LED MicroStrip Plate Light *VFX Running Light FX Kit *VFX Universal Flasher Relay *Yamaha European Ignition Key *Yamaha Tuning Fork, Aluminum Brake Reservoir Cover (black)*
Its heaven and hell here, which one will I live today?
Yamahauler is offline   Reply With Quote
Old 01-21-2008, 06:16 PM   #5
jayj024
Bike: 2000 R6
Good point. I didn't even try to install it yet. Thanks for the input everyone.
Devil SB2 vs. Micron slip on s14roller Exhaust and fuel delivery 18 06-20-2007 01:26 AM
2006 R6 slip on question cls06r6 General Discussions 4 01-23-2007 07:09 PM
Finally decided on a slip on! Termi Question LuvMyR6 Exhaust and fuel delivery 2 06-21-2006 10:44 PM
05 ZX6 Micron dual vs Arata slip on Birdman Exhaust and fuel delivery 0 11-14-2005 06:44 PM
micron question Ryan50hrl Exhaust and fuel delivery 0 04-11-2005 09:57 PM
