I dont know if it's overkill, but it will stand out for sure.I went with black because, well it's just me.My car has the same theme, black w/ a little blue here & there.
they sell pre painted bolt kits www.tastynuts.com is one they are a little pricy but i bought mine fromsomewhere in the us (cant remember where) but search around
__________________ 2005 r6 raven, Motodynamic sequential signals, flush smoke front turns, 8k hid low, Devil racer carbon highmount ceramic coated black, Ohlins steering dampner, Motovation no cut frame sliders and bar end sliders, ASV levers, Vortex black rearsets, Corbin seat, K&n air filter, Factory Pro +4 ignition advancer, superflare vstacks, and slide stops, -1 520 conversion, Goodridge Shadow brake lines, Zero gravity windscreen, Stompgrip tank pads, NRC powdercoated racing covers, HINSON SLIPPER CLUTCH, Vented Brakes cooling system, Racetech internals front and rear with Michelin Power Pures holding it to the road
Try some reflective rim strips to be seen they will do wonders, and you dont need to run wiring for lights. These will only help you to be seen from the side. For the front try some HIDs and an LED tail light for the rear. Good luck with the bolts!
I agree Paint them Dark metalic red. Do it like the candy apple matte on the mid fairing of the 08 R1. That would look hot. Or if you have other chrome on the bike chrome dip them... Careful though if you paint them it will eventually chip off. Especially at high speeds, and especially when you put them back on with the screw driver...
