How to launch good : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > Racing and Stunt Discussion > Drag Race Section
Old 05-19-2008, 09:06 PM   #1
3ndo_R6
Bike: 2007 R6
How to launch good
so i went to the track here in calgary alberta on friday and these were my times.
2007 R6
R/T ... 0.542
60ft ... 2.196
1/8 ... 8.149 @ 95.62Mph
1/4 ... 12.268 @ 117.35Mph
I'm 205lbs, 6'2"
i have no idea what rpm i should be launching at or how i should be doing it but i know if i can get a better launch i can hit 11's. so any tips on what i should be doing, at what rpm i should i be launching at?
3ndo_R6 is offline   Reply With Quote
Old 05-22-2008, 10:07 PM   #2
panago
max speed
Bike: 2003 Blue R6
Re: How to launch good
I usually launch around 6k and then slip the clutch out to about the 60' mark while adding throttle gradually. Sometimes I barely use full throttle in first gear so I can keep the front down because if it comes up more then a couple of inches it will slow you down. I'm 6'0 and 155 suited up btw. If you can get your 60' below 2 then you will easily be in the 11's. My 60' is usually high 1.8 to low 1.9
2003 Blue R6 10.84@128
Chad
panago is offline   Reply With Quote
Old 05-29-2008, 06:43 PM   #3
rideblue450
throttle jockey
rideblue450's Avatar
Bike: 2007 Grey/Charcoal R6
Send a message via AIM to rideblue450
Dude you can easily hit 10's with a good launch. I went 11.1 with a 1.8 and that was hangin the front wheel. i forget the mph
sold...\/
full yosh system
black pazzo shorties w/silver sdjusters
smoked hotbodies flushies/integrated tail light
black puig double bubble
PCIII/tune
SS braided lines F/R
shogun no cut sliders/bar ends/spools
rideblue450 is offline   Reply With Quote
Old 06-01-2008, 05:15 AM   #4
momosl
momosl's Avatar
I took my wifes R6 to the track a few times. She has a 01 R6. Two weeks ago I ran a 11.16@124 with a 1.81 60ft. I brought it up to 10-11,000 and launch slipping the clutch for a very short time. Another hint is, do not let off the gas at all. Tap your clutch very little and you will be able to speed shift the whole way down the track.
It's not what you buy, It's what you build
momosl is offline   Reply With Quote
Old 06-01-2008, 05:28 AM   #5
FrannieFresh
I'll do my best.
Bike: Blue '07 R6, '10 R1 Raven
Send a message via AIM to FrannieFresh
Basically, you want to rev the engine to the point where it has maximum torque, not max HP.
mods: HotBodies smoke flush mounts, fender eliminator, integrated LED rare signals, frame slidders, twobros M-2 can.
coming soon:twobros 4-2-1 headers and mid pipe, puig windscreen, pazzo shortie levers, PCIII.
FrannieFresh is offline   Reply With Quote
Old 06-02-2008, 07:39 AM   #6
falke401
I launched at about 9K rpm slipping the clutch. That got me a 1.7 60'. 10.63 @130. Thats with stock gearing, and the front end strapped.
05 R6
falke401 is offline   Reply With Quote
Old 06-02-2008, 02:43 PM   #7
3ndo_R6
Bike: 2007 R6
well i went back last week and these were my times. still doing bad on the 60'
R/T ... 0.111
60' ... 2.125
1/8 ... 7.852 @96.94
1/4 ... 11.922 @ 118.67
Old 06-02-2008, 08:48 PM   #8
falke401
wow your mph is also way low. are you using the clutch in all the gears? from now on just use the clutch in first, the rest just preload the shifter and blip the throttle. the 1-2 shift is a little scary at first, but just do it and you will be fine.
Old 06-03-2008, 02:57 PM   #9
3ndo_R6
Bike: 2007 R6
i already shift with out the clutch, remember i'm not at sea level here
Old 06-03-2008, 02:58 PM   #10
3ndo_R6
Bike: 2007 R6
what rpm is the best to shift at? i have been shifting just before redline
i'm impotent =( deltaonex General Discussions 43 01-06-2012 09:23 AM
$3500 for 2000 r6.... more info inside...Is it a good deal? bassfishingboy General Discussions 11 08-15-2008 11:10 AM
i give good advice, am i rite? registeredtopost Appearance and Exterior Mods 5 06-04-2007 08:56 PM
Jerez Results **SPOILER** yoda RACE Section 3 03-29-2007 10:30 PM
good security question... grep_rask General Discussions 8 05-13-2005 07:33 AM
