ignition wiring diagram : Yamaha R6 : R6 Forum
Old 06-09-2008, 02:03 PM   #1
Killians31
Chi-Towns Finest
Killians31's Avatar
Bike: 2005 R6 Metalic Blue
Send a message via AIM to Killians31
i am about to finish hooking up my bike alarm, and need to tie into the ignition wires to prevent it from being stated when the alarm is on.
by any chance does anyone have a diagram of the ignition wires for an 05?
Thanks
2005 Yamaha YZF-R6
Spy LM508 Alarm
Clear Alternative Integrated LED Tail
8K 35Watt HID's
Blue CCFL Angel Eyes
Paint Matched Headlight Housing
Rerouted Daytime Running Lights
Flush Mount Turn Signals
Sprint Steering Stabilizer
Custom R6r Exhaust
Blacked Out Windscreen
Blue Rim Tape
Ram Air Grill
Fender Eliminator
Removed Rear Hugger
Shaved All Stickers
TSR Frame Sliders
TSR Clutch Slider
Rear Spools
Pro Grip Tank Pad
Killians31 is offline   Reply With Quote
Old 06-09-2008, 09:40 PM   #2
Agent4573
Studmuffin
Bike: 04 R6
Send a message via AIM to Agent4573
Re: ignition wiring diagram
Theres 4 wires going to the ignition. If you follow them under your tank there are two connectors, a red one and a white one. The main power +12 volt constant is the red wire in the white connector. The other wire in white connector is the switched +12 volt that is only on when the key is on.
Blue 04 R6. - Sold
Agent4573 is offline   Reply With Quote
Old 06-09-2008, 10:25 PM   #3
Killians31
Chi-Towns Finest
Killians31's Avatar
thanks for the reply agent!
i am going to have to take a look at it tomorrow and see what i can get done.
out of curiosity, what are the other two wires?
2005 Yamaha YZF-R6
Spy LM508 Alarm
8K 35Watt HID's
Custom R6r Exhaust
Blue Rim Tape
Ram Air Grill
Fender Eliminator
Removed Rear Hugger
Shaved All Stickers
TSR Frame Sliders
TSR Clutch Slider
Rear Spools
Pro Grip Tank Pad
Old 06-10-2008, 09:25 PM   #4
Agent4573
Studmuffin
Bike: 04 R6
They are power/ground/do something with the starter circuit cutoff relay. If you put +12 volts into the wrong one of them, it fries the starter circuit and brings on a whole new headache, which can be solved by grounding both of them, and then taping over the neutral light that will constantly be on.... yeah, ask me how I know about that....
Blue 04 R6. - Sold
Old 06-10-2008, 10:04 PM   #5
Killians31
Chi-Towns Finest
Killians31's Avatar
alright so it looks like for my alarm, i am going to have to tire into the other wire in the white connector (not the red one) for my alarm to cut power to the ignition when the alarm is locked
at least from my understanding...
Thanks again
2005 Yamaha YZF-R6
Spy LM508 Alarm
8K 35Watt HID's
Custom R6r Exhaust
Blue Rim Tape
Ram Air Grill
Fender Eliminator
Removed Rear Hugger
Shaved All Stickers
TSR Frame Sliders
TSR Clutch Slider
Rear Spools
Pro Grip Tank Pad
Old 06-12-2008, 02:28 PM   #6
Killians31
Chi-Towns Finest
Killians31's Avatar
by any chance do you remember what color wire it was, i cant seem to get to the connectors...i can get to the wires, but the connectors are hidden under the tank which i cant get to
2005 Yamaha YZF-R6
Spy LM508 Alarm
8K 35Watt HID's
Custom R6r Exhaust
Blue Rim Tape
Ram Air Grill
Fender Eliminator
Removed Rear Hugger
Shaved All Stickers
TSR Frame Sliders
TSR Clutch Slider
Rear Spools
Pro Grip Tank Pad
Old 06-12-2008, 10:00 PM   #7
Agent4573
Studmuffin
Bike: 04 R6
I think it was brown. My bike isn't here right now or I would go look. There are two wires that are 16 gauge(thicker) and two wires that are 18 gauge(thinner). The thicker ones are your main power wires. You'll want the thicker, non-red wire it sounds like.
Blue 04 R6. - Sold
Old 06-14-2008, 06:57 AM   #8
w16036
diagrams and wire colors here
http://www.r6messagenet.com/forums/r...ir-manual.html
w16036 is offline   Reply With Quote
Old 08-02-2008, 11:22 PM   #9
schrec44
U.S. Marine
schrec44's Avatar
Bike: 08 Raven R6
Images: 4
Pictures would be awesome
Bike:
GYTR slip-on | Framesliders | Swingarm spools | LP Racing Flushmounts | Comp Werkes Fender Eliminator | Scorpio SR-i900 Security System | Scotts Steering Damper | PUIG Windscreen | DDM 6000K HID's | Vortex Rearsets | ASV Levers | R6-Forum Reservoir Cover (Thanks Agg) | Powdercoated Passenger Pegs (Thanks Agg) | Vortex Racing Sprockets 16/45 | DID 525ZVM-X Chain
Gear:
Alpinestars RC-1 1-Piece Suit | Alpinestars SMK Leather Jacket |Shoei X-12 Kiyonari TC-2 | Shoei RF-1000 TC-2 | Alpinestars SP-X Gloves |Alpinestars GP Pro Gloves | Alpinestars S-1 Gloves | Icon ARC Pants | Alpinestars S-MX 1 Boots | Alpinestars S-MX 5 Boots | Alpinestars Track Vest
Yut Ughh
schrec44 is offline   Reply With Quote
Old 08-03-2008, 03:39 PM   #10
Agent4573
Studmuffin
Bike: 04 R6
also, the wiring diagram in the manual is misleading. It shows a single hot wire going to the ignition, and 2 switched wires. The way its drawn up, it looks like all 3 switched wires get +12 when the key it turned on, do that and you'll fry your ignition relay. Thats why I didn't post a link to the manual, because its wrong in this case.
Blue 04 R6. - Sold
scorpio ignition disable wiring bigdanlikewhoa General Discussions 3 02-17-2011 09:21 PM
help w/ engine code MARKo Garage / Mechanical Help 19 01-21-2010 08:44 PM
wiring Remote Ignition Disable (Anti-Hijack) itsboosting Garage / Mechanical Help 3 06-11-2008 10:14 AM
Ignition and keys with ecu WANTED! buchern Bikes Parts For Sale 0 09-21-2006 10:54 AM
2003 R6 wiring diagram and how to remove ignition switch gp125_racer General Discussions 2 05-21-2004 01:32 PM
