Sparkplugs on a 2001 R6??? : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > How To's...
Old 08-13-2003, 06:45 AM   #1
jasamb
Does anyone know a good way to change the plugs on a 2001 R6? i havel't tried yet, but from th looks of things, it is not going to be easy.
jasamb is offline   Reply With Quote
Old 08-13-2003, 09:11 AM   #2
dj1298
It really isn't that hard.
Take your tank off completly.
Then remove the air box. There is about 4 hoses that connect to the box, plus the 4 clamps that hold it to the carbs.
Next is a plastic liner that needs to come out. This is a little tricky because you have to move it several directions to get it to come out of the frame.
Now you should see the head of the motor. Just pull out the spark plug wires and use the spark plug socket that came in the tool kit.
When you put it allback together be sure to put hte plastic liner back in. Not sure what it does, but I am sure it has a reason for being there.
dj1298 is offline   Reply With Quote
Old 08-13-2003, 11:17 AM   #3
jasamb
Thanks for the advice. Not something I will do now, but over the winter I will try this and post my results.
2001 R6 Frame Sliders mwong168 Appearance and Exterior Mods 5 06-21-2006 08:46 AM
So how far off would a 2001 R6 speedo be? klif01 Garage / Mechanical Help 5 06-08-2006 09:29 AM
Just bought 2001 r6! good price? mxracer1618 General Discussions 11 05-28-2006 02:26 PM
TSR Report - Stock 06 R6 vs. Not So Stock 06 R6 extrakt0r General Discussions 2 05-14-2006 01:15 PM
2001 r6 help grep_rask General Discussions 3 05-16-2005 01:25 PM
