raising the rear end : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Suspension settings
Old 11-10-2003, 01:25 PM   #1
speedfreek
What's the best way to raise the rear end for quicker turn-in?
Has anyone done this? What products are available?
Speedfreek
speedfreek is offline   Reply With Quote
Old 11-10-2003, 06:39 PM   #2
Jeffsy
Jeffsy's Avatar
It'd probably be easier to drop the forks through the triples a bit to get the same effect ??
Jeffsy is offline   Reply With Quote
Old 11-10-2003, 08:01 PM   #3
jasamb
Yes, do that.
"Treat it like you love it , ride it like you hate it"
PEOPLE WHO THINK THEY KNOW EVERYTHING ANNOY THOSE OF US THAT DO!
jasamb is offline   Reply With Quote
Old 11-11-2003, 12:16 PM   #4
speedfreek
well yes I know that but I want maximum ground clearance. Plus it'd make a slightly cosmetic improvement
Speedfreek
Old 11-11-2003, 01:02 PM   #5
jasamb
AAAHHHHHHH...
Planning to race motorcross on your R6 huh?
Or are you like 9 feet tall?
If you raise the center of gravity, you may lose some control
Old 11-11-2003, 02:01 PM   #6
speedfreek
Not so much. Thanks for the advice all.
Speedfreek
Old 05-14-2004, 04:13 AM   #7
BRAVO
yes i need to raise the rear for my track day, anyone know how
THE MILEAGE MURDERER,SCRATCHIN ASSASSIN
BRAVO is offline   Reply With Quote
Old 05-14-2004, 04:53 AM   #8
drhodes
looking for more curves
Get a taller shock.
drhodes is offline   Reply With Quote
Old 05-14-2004, 01:43 PM   #9
speedfreek
You can replace the linkage Dog bones or plates. Try places like demon tweaks, m and p, mps, busters, tts performance, bigcc racing, performance motorcycle parts, HPS (where I just got my ignition advancer).
You could also try ebay. That's where I got mine. mine works by replacing the linkage plates with ones of a slightly different geometry. Haven't ridden the bike with them fitted yet (waiting for the funds to buy a steering damper). It looks the nuts though. Visibly raises the back end. Looks more agressive.
Pics and a full report will follow soon.
Speedfreek
Old 05-29-2004, 01:42 PM   #10
R6#319
Hang on, there's a much easier way to do it. All you have to do is get a couple of shims (washers) and put them on the top of your stock shock. It's quite easy to do. Remove your gas tank, seat(s) so that the nut on the top of the shock is exposed.
It's nice to have a front end stand for stability, but if you've got a buddy or two that will help you're set.
What you need to do is remove the nut that's on the top of the shock. If you look where the top of the shock mounts to the frame, you'll see that there's a U-shaped bracket on the top of the shock. Welded to that U-shaped bracket is a piece of threaded rod. The threaded rod goes through the frame and the nut holds the threaded rod.
What you want to end up with is a shim/washer between the U-shaped bracket and frame. You DO NOT need more than two washers in there, in fact I'd try one first.
So, you've undone the nut that's on the threaded rod. Next you want your buddies to lift the rear end of your bike up high enough so that the threaded rod comes out of the frame.
Then place ONE washer over the threaded rod and reverse the process. What I've done in the past (when I couldn't get someone to give me a hand) is I got 2 tie downs and secured them to the subframe and the rafters of my garage. Then you can lift and lower the rear end of your bike yourself.
This is an easy mod to do and doesn't take much time at all. But, I wouldn't recommend it unless you're going to spend some time getting your suspension sorted on the track.
Here's a pic :
AL
"Miss Hoover can I have another worm ? I ate mine" - Ralph Wigam
R6#319 is offline   Reply With Quote
high side?? nybimmer General Discussions 22 03-09-2008 07:50 AM
Static sag + rear stand slepax Suspension settings 2 12-28-2005 03:52 PM
Raising the rear lvbluer6 Suspension settings 13 10-12-2004 08:19 PM
70 front and raising rear ride height RedlineR6 General Discussions 9 07-20-2004 09:28 PM
Raising rear ride height, shimming the shock ? R6#319 Suspension settings 8 05-31-2004 06:31 AM
