'06 R6 Throwing Error 1 Code : Yamaha R6 : R6 Forum
Old 05-06-2009, 04:02 PM   #1
gi0220
Bike: '06 R6 - Bone Stock
My 2006 R6 is throwing an error1 code at me on the gauge. Its not turning over but the battery is not dead b/c gauges wake up and the headlight comes on etc. I dont have access to the manual to look it up, anyone know what error1 is all about?
Thanks
2006 R6 - Bone Stock
1970 Pontiac GTO - 454 Chevrolet
2004 Honda Civic - The DD
gi0220 is offline   Reply With Quote
Old 05-06-2009, 10:21 PM   #2
hanasanaid
Bike: r6s, gsxr 6, f4i
Re: '06 R6 Throwing Error 1 Code
just so you know, the starter takes many more amps than anything on the bike, everything else can work perfect and the battery can be bad,
i dont know what the code means, but find out what exactly it does, does the starter relay click? does the starter make any noise?
hanasanaid is offline   Reply With Quote
Old 05-07-2009, 08:23 AM   #3
gi0220
The relay clicks and the starter makes noise but it doesnt turn over. Im going to call my local shop today to find out what that code means. will post when i find out.
Old 05-07-2009, 08:33 AM   #4
strapedR6
Bike: Junk
Images: 2
If the code says ER-1 than it is - No signals are received from the ECU.
there is no diag code 1 only error code
strapedR6 is offline   Reply With Quote
Old 05-07-2009, 09:47 AM   #5
gi0220
yep ER_1, also i called a few local shops and no one could give me an answer. the closest i got was one tech telling me that the code is for fuel injection which makes no sense considering my problem.
Old 05-07-2009, 12:12 PM   #6
strapedR6
Bike: Junk
Images: 2
Take ur seat off an see if the main ECU fuse is blown... Do u have some sort of ecu piggyback? ie: PC3, bazzazz ROM Tune
Old 05-07-2009, 12:16 PM   #7
gi0220
no piggybacking items. I'll check the fuses in a few hours when i get home from work. Any chance i just need a new battery? someone else suggested thsi might be the problem.
Old 05-07-2009, 12:24 PM   #8
strapedR6
Bike: Junk
Images: 2
check battery voltage as well...
Old 05-07-2009, 12:32 PM   #9
gi0220
super noob, how do i go about doing that? can i take it down to advance auto or auto zone and have them put it on their reader?
Old 05-07-2009, 12:42 PM   #10
strapedR6
Bike: Junk
Images: 2
Unless u have ur own volt meter.. in that case it should read 12 volts or more to start... if u dont have one u could bring it to the places stated above... if it reads under 12 volts replace it... i always use oe batteries a little expensive but some motorcycle stores online sell the oe ones for $40
R6 Service Manual Fault Code Table pnrfame Garage / Mechanical Help 19 09-25-2014 07:41 PM
'06 R6 vs '06 GSX-R600 i've ridden both!!!! Joe2D General Discussions 56 02-19-2010 10:31 PM
05 R6 throwing code 20 acrproject Garage / Mechanical Help 0 03-15-2009 03:20 AM
06 r6 code 18? blu06r6 Garage / Mechanical Help 5 06-09-2008 07:21 AM
Keep Throwing Code 24 money911 Garage / Mechanical Help 0 07-25-2007 10:54 AM
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
