Tire Air Pressure : Yamaha R6 : R6 Forum
Go Back   Yamaha R6 Forum: YZF-R6 Forums > R6 Related Discussion > Tire Tech Talk
Old 05-14-2004, 09:37 AM   #1
Ed
Tire Air Pressure
I can't remember the Yamaha recommended settings for tire air pressure off hand, but I remember when I checked my tires' air pressure yesterday before I went riding, each tire was 1 PSI below the recommended. I was just doing normal street riding.
Is this 1 PSI below recommended settings alright to ride on or should I have just filled the tires up to recommended settings?
And does tire air pressure increase after you've ridden around for a while? Say half a PSI or 1 PSI?
Ed is offline   Reply With Quote
Old 05-14-2004, 09:48 AM   #2
Lewdicrous
Send a message via ICQ to Lewdicrous Send a message via AIM to Lewdicrous Send a message via MSN to Lewdicrous Send a message via Yahoo to Lewdicrous
Is the yamaha recommended pressures the same as the tire manufacturers recommended pressures?
I change my pressures depending on what type of riding I am going to do.
1 PSI wont really make that much of a difference.
And yes, after your tires warm up the air warms up inside and can raise the pressure depending on the temp.
which is why you should check your tires cold to get more consistant readings.
"Search" is your friend.
SoCal Bike Nights
-Jake
West Siieeeeede Newbury Park
Lewdicrous is offline   Reply With Quote
Old 08-05-2004, 05:00 PM   #3
Big_Perm
I run 36 front and rear, and always will. The recommended for my bike is 42!! That is WAY too hard, and it makes my tires slide around because of the small contact patch. You should adjust the pressure to the type of riding you do. More for easy riding, less for more aggressive riding. If you go too low, your tires will fold in a turn, and you can break the bead, resulting in a bad day.
Miraclegrau's mechanic, among other things...
Big_Perm is offline   Reply With Quote
Determining Best Tire Pressures james1300 General Discussions 0 11-17-2006 08:12 AM
Qualifier tire pressure.... LDROWN Tire Tech Talk 20 09-24-2006 10:37 PM
Tire pressure on '06 R6 jonLr6 General Discussions 10 03-08-2006 12:04 AM
Your Tire Pressure? Tommy2003R6 Tire Tech Talk 3 08-23-2005 07:36 AM
Does anyone change their own tires..... jasamb Tire Tech Talk 19 08-12-2005 04:22 AM
