Should have read this first before just all out replace the tps. Pulled it off and yup, was dirty as hell. Since I got the new TPS, I just put the new one one. Feels good to have good throttle response back, specially on the low end. Always hesitated and had the stupid idle/stall issues. Great write up!
if you have no issues with throttle response or jumpy idle, then you are fine. I think most issues are with sensitivity on the low end when you roll on the gas around town or have a ****ed up idle.
Ok cool. What exactly does the TPS control? What would theoretically happen with a lower max value? (ex: 94 instead of 97-100).
Exactly what full name implies. It's a Throttle Position Sensor, it is used to tell the ECU where the throttle is at: closed, full open or in between; usually in percentage. It's helpful for the ECU to know this for ignition and fuel injection timing.
"Government big enough to supply everything you need is big enough to take everything you have. The course of history shows us that as a government grows, liberty decreases."
— Thomas Jefferson
Wow I couldn't even imagine how your bike ran... must of been shitty. Did u clean it and redo it? Can't see it being stll good but good news if you haven't done already, there was a recall for your year so check that out. Let us know what u do
