Engine ice for regular street use? - Page 2 - Yamaha R6 Forum: YZF-R6 Forums
post #11 of 16 (permalink) Old 02-09-2017, 08:55 PM
The Black Widow
Bike: 2005 Raven
Re: Engine ice for regular street use?
I often found that at stop lights or cruising at low speed on a hot day my temp would rise to 205+. Though i'm sure it is normal I switched to engine ice and it seems to help out in those situations.
Speedcrazed is offline
post #12 of 16 (permalink) Old 09-11-2018, 11:41 AM
How often to change Engine Ice?
Geo168 is offline
post #13 of 16 (permalink) Old 05-17-2019, 08:37 AM
205? That's pretty low it seems. I had an RSV4 that would push high 230's on hot days. It was quite unpleasant.
IssyR6 is offline
post #14 of 16 (permalink) Old 05-17-2019, 02:57 PM
Bike: 2015 R1
Garage
it's actually garbage. I've seen many guy's bikes puke this stuff out after being ran hard. just use regular coolant. peak, prestone, zerex etc.
and yes, 205 on a R6 is normal. the fans come on at 215 and turn off at 212. while you're moving around 50 and above your bikes should be around the 180 to 190.
remember the bike's come lean from the factory. running a map with a lower air fuel ratio like 13.5 to 1 instead of 15 to 1 will make it run cooler too. also your engine oil choice, it may be inadequate. engine oil's second job is to cool the engine. if you're using car oils STOP. they're not designed for high revving engines and keep it cool.
yamahacrazy is offline
post #15 of 16 (permalink) Old 05-17-2019, 04:04 PM
Originally Posted by yamahacrazy View Post
.......... if you're using car oils STOP. they're not designed for high revving engines and keep it cool.
Supposedly they contain friction modifiers that aren't good for wet clutches.
Intuit is offline
post #16 of 16 (permalink) Old 05-18-2019, 08:34 AM
Bike: 2015 R1
Garage
yeah it's not that the oil is bad per se. its you don't know what the additives are and if they have a negative affect. if they say they passes Jaso MA or MA2 certifications then it should be ok for the clutch. the other thing to consider if you want to use car oils is that the manufactures are the voices behind what the oil companies have to do to make their oil meet their specifications.
flat tappet engines are history in cars. but in motorcycles such as sportbikes they are the current design. so a car oil will have less of the additives or properties needed to protect these engine parts. zinc is one of these additives. most modern car oils have very little if any of it. whereas a motorcycle specific oil has a lot to protect the lifters and cams.
people just think oil is oil. but if they had the data presented to them they'd realize how much damage they can be doing by using car oils in a motorcycle. yeah I've seen the stories of guys always using it and have over 100k. but I don't know if they're telling the truth. I'll stick to using what standardized testing(jaso, sae and astm) proves and what engineers recommend.
Regular engine oil or synthetic ?? dewana421 General Discussions 8 09-04-2011 08:45 AM
engine ice...engine coolant mrzachsa Oil and Lubrication 17 02-24-2011 04:34 PM
Engine Ice nycboy7 General Discussions 5 02-08-2009 06:26 PM
Engine Ice oarce_r6s General Discussions 13 08-02-2008 10:49 AM
Engine Ice? MotoAce51 Oil and Lubrication 30 06-18-2008 05:19 PM
