Yoshimura Alpha T Works Exhaust System for YZF-R6 - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 9 (permalink) Old 02-20-2019, 08:07 AM Thread Starter
Platiunum Supporting Sponsor
RidersDiscount's Avatar
Bike: R1, 675R, Grom
Yoshimura has always led the way when it comes to performance exhaust systems for fast bikes. And more recently, they’ve turned their attention to refining the looks of their exhaust systems in the form of the Works Finish series exhaust. From tip to tail, well – almost to tail, the exhaust is assembled using 304-L grade stainless steel that’s tipped at the very end with a carbon fiber end cap. A set of black aluminum exhaust flanges on the primary headers
All of that metal, save for the flanges and assembly springs, is covered in Yoshimura’s Works Finish err, finish. Out of the box, you’ll find it has a satin gray look to it, but once fitted to the bike, and after some heat has been through it, the system changes into a unique bronze color that’s reminiscent of a true kit exhaust system. But that’s not just pukka race looks, it’s actually a carefully engineered exhaust system that’s CNC-mandrel bent for a perfect fit and significantly improved exhaust flow over the stock system.
If weight savings are of a concern, you’ve come to the right exhaust – the entire system weighs 11.1 lbs. compared to the OEM weight of 21.8 lbs. That’s a smidge under half the weight as stock. As far as replacement stock components goes, there isn’t a single item that you can replace on your bike with off-the-shelf goods that provides that kind of weight savings.
You can read more about this exhaust on our website
, or - to get this stellar exhaust shipped to your door, call TJ on 866.931.6644 ext. 817, send a note to
, or just shoot us a PM and we’ll get back to you right away.
Check out the dyno data provided by Yoshimura on a machine with stock fuel parameters. A competent tuner will not only smooth out that lines, but provide you with even better power output.
Name:	Yoshimura Alpha T Exhaust System for YZF-R6 2017-2019 (16 of 17).jpg
ID:	359988   Click image for larger version
Name:	Yoshimura Alpha T Exhaust System for YZF-R6 2017-2019 (1 of 17).jpg
ID:	359990   Click image for larger version
Name:	Yoshimura Alpha T Exhaust System for YZF-R6 2017-2019 (14 of 17).jpg
ID:	359992   Click image for larger version
Name:	Yoshimura Alpha T Exhaust System for YZF-R6 2017-2019 (3 of 17).jpg
ID:	359994   Click image for larger version
Name:	Yoshimura Alpha T Exhaust System for YZF-R6 2017-2019 (12 of 17).jpg
RidersDiscount is offline
post #2 of 9 (permalink) Old 02-27-2019, 07:58 AM
No i cant wheelie officer
TuckeR6's Avatar
Bike: 07 r6r
Garage
Re: Yoshimura Alpha T Works Exhaust System for YZF-R6
How much?
TuckeR6 is offline
post #3 of 9 (permalink) Old 02-27-2019, 07:59 AM Thread Starter
The full stainless system has an MSRP of $968.42
post #4 of 9 (permalink) Old 02-27-2019, 11:15 AM
Curious do you guys carry the full titanium set? Oversaw some
sound clips and apparently, tuning is "optional" as the system was developed using stock settings, is this confirmed?
bweezy is offline
post #5 of 9 (permalink) Old 02-27-2019, 11:17 AM Thread Starter
I do not have the full titanium systems in stock, but it is something we can special order for those looking. We always recommend tuning as the stock bikes generally run lean.
post #6 of 9 (permalink) Old 04-05-2019, 10:39 PM
Ilonummi@gmail.com's Avatar
Do you not use the manifold gaskets?
post #7 of 9 (permalink) Old 04-06-2019, 07:36 AM Thread Starter
Originally Posted by
View Post
We didn't use them on our race systems (Akrapovic at the time) and according to Yoshimura they give the following disclaimer:
Note: The stock exhaust port gaskets will not be
used with the Yoshimura full-system.
Remove gaskets from exhaust ports
before installing Yoshimura manifolds.
Here is a link to their instructions:
post #8 of 9 (permalink) Old 04-06-2019, 11:23 AM
Thanks for your input.
post #9 of 9 (permalink) Old 04-08-2019, 09:43 AM Thread Starter
No problem
Looking for alpha t race r6 exhaust! FlyMode Bikes + Parts + Gear Wanted 1 03-28-2019 04:30 PM
Full system M4 vs Full system Yoshimura Alpha T Sky Bao Nguyen Exhaust and fuel delivery 3 12-19-2018 05:53 AM
Looking for GP style exhaust system for 07 r6 r6socal Exhaust and fuel delivery 7 12-06-2018 03:01 PM
Yoshimura - Alpha T Race Series Works Finish Full System 2006-2018 Yamaha R6 cutback Bike Parts For Sale 21 11-27-2018 07:12 PM
How To: Install Wolf Slip-On (Standard Mount) for 2004 R6 Ed How To's... 4 04-30-2004 10:57 AM
