Yuasa YTX AGM Maintenance Free Batteries - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 04-23-2019, 09:13 AM Thread Starter
Platiunum Supporting Sponsor
RidersDiscount's Avatar
Bike: R1, 675R, Grom
Available for modern just about every bike out there, Yuasa batteries have long been the battery of choice for OEM manufacturers, which makes the YTX variant an ideal replacement when the OEM unit has reached end of life.
Featuring absorbed glass mat (AGM) cells, all you have to do is add the pre-measured acid pack, charge as directed, and install the battery in your bike. Thereís no guesswork here as itís all laid out perfectly for you with everything thatís included in the box.
Since the battery is of a sealed design, thereís no worry about acid spillage, or even having to refill the battery later on. Just fill it up and forget it! The AGM design allows the battery to stand for longer, without a charge, than conventional flooded batteries. This makes it an ideal choice for riders that have long stints between rides.
And given that each battery is built in an OEM-sized chassis, with the leads correctly oriented, fitting the battery to your bike is about as simple as it gets!
To order yours, give TJ a call on 866.931.6644 ext 817 to get the correct Yuasa battery for your ride sent straight to your door. Of course,
or a PM works, too!
Name:	RD Yuasa YTX9-BS Battery-1.jpg
ID:	360990   Click image for larger version
Name:	RD Yuasa YTX9-BS Battery-2.jpg
RidersDiscount is offline
Firepower Lithium Batteries RidersDiscount Riders Discount 2 04-09-2019 12:18 PM
Good maintenance habits for new owner please Raven2010R6 New Member Section 13 01-24-2019 02:15 AM
2002 - Replaced faulty starter unit, free spins/no crank. Megarenr Garage / Mechanical Help 2 10-12-2018 06:01 AM
