Alpinestars Hyper Drystar Motorcycle Jacket - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 1 (permalink) Old 09-13-2019, 09:49 AM Thread Starter
Platiunum Supporting Sponsor
RidersDiscount's Avatar
Bike: R1, 675R, Grom
One jacket for all conditions; the Hyper Drystar is just the right combination of breathable comfort, and waterproof protection.
CE-approved armor is fitted in the shoulders and elbows and compartments for a back protector and chest inserts are included if you really want upgraded protection. Itís all housed in a heavy-duty, yet flexible poly fabric, dobby-reinforced covered in an Alpinestars Drystra taped-seam chassis.
Particularly unique for this jacket is the way it can be adjusted to fit your bodyís exact shape. Tabs are found on either side of the torso, along with hook-and-loop drawstrings at the waist. In the arms, too, is another set of hook-and-loop tabs that draw the jacket as close, or far Ė as you want from your body. The result is a keenly fit jacket thatíll keep you dry when the skies open up.
Ventilation is looked after via a series of zippered intakes on the front and back of the jacket. These, of course, can be drawn closed when itís cold, or rainy, but are more than capable of moving lots of air when needed. And we should mention that, inside the jacket, youíll find a removable liner, too, for the really cold weather.
This jacket isnít a one trick pony Ė rain or shine, hot or cold, itíll get the job done for a lot of riders!
Get this jacket by giving TJ a call on 866.931.6644 ext 817. Or, just send a note to
with ALPINESTARS HYPER DRYSTAR JACKET the subject line and weíll get back to you right away.
Name:	RD Alpinestars Hyper Drystar Jacket 1.jpg
ID:	363306   Click image for larger version
Name:	RD Alpinestars Hyper Drystar Jacket 4.jpg
ID:	363308   Click image for larger version
Name:	RD Alpinestars Hyper Drystar Jacket 11.jpg
ID:	363310   Click image for larger version
Name:	RD Alpinestars Hyper Drystar Jacket 12.jpg
ID:	363312   Click image for larger version
Name:	RD Alpinestars Hyper Drystar Jacket 5.jpg
RidersDiscount is offline
