1st Gen R6 Track Bike - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 12 (permalink) Old 11-12-2018, 10:31 AM Thread Starter
motojay64's Avatar
Bike: 2000 R6 & 2015 R3
Garage
Does anyone else track a 1st gen R6? I recently wrecked mine got a pretty bad concussion and decided to completely tear down and start from scratch. Long story short I picked up my 2000 R6 for $600 runs and drive.
I've got a few questions and looking for some help or ideas. This is my first full track build.
I've redone the wiring and planned on removing the clutch side switches, but worried about the choke. Any suggestions on possibly relocating that? Im also looking into doing a keyless entry. Any suggestions on how to wire that to just a simple small toggle switch?
Im sure I will have more questions the more I start putting thing back together. I replacing every nut and bolt on the bike. The put way to much trust in the kid I bought it from and the bike was literally put together with just random hardware and nothing matched...
Any help tips, tricks or ideas are very appreciated !
ID:	358802   Click image for larger version
ID:	358804   Click image for larger version
motojay64 is offline
post #2 of 12 (permalink) Old 11-12-2018, 11:31 AM
Hey...watch this
FZ1guy's Avatar
Bike: FZ1; R6; GL1800; SV650
Re: 1st Gen R6 Track Bike
I wouldn't worry about the left side switches and such. You will probably still want the clutch switch so you can start in gear. And of course the choke. No one else removes the left side stuff. Replacing the key with a toggle switch is easy. I can't recall the color codes, but there are only 4 wires and it is obvious when you look at a wiring diagram. The Gen1 is a fine track bike. Concentrate on getting the suspension right for your weight. If you don't have tire warmers get some Q4's for the track.
FZ1guy is offline
post #3 of 12 (permalink) Old 11-12-2018, 12:00 PM Thread Starter
motojay64's Avatar
Garage
I was thinking about that too. I've been in the garage every single night doing little by little trying to do this the right way. Im still debating on repainting the frame and swing arm. I did wet sand it and clean it to but still doesnt look "nice" Ive pulled all the wiring out for any lights and cleaned that up in some nice wiring looms. Cleaned and degreased the motor. Im replacing all the main wearable items like sprockets, tires and what not. Started drilling bolts for safety wiring. I do have a set of Q4s waiting for it and tire warmers. I got a base suspension tune on it now that I had done when I took it to its first track day. I plan on doing everything the correct way so I dont end up on the ground again
post #4 of 12 (permalink) Old 11-12-2018, 02:04 PM
We just finished relocating the choke lever on my son's bike. We used a lever from a fzr600 (it mounted on the frame, between the frame and fairing) and mounted it to the front sprocket cover. Of course this required building a custom cable, but it does look quite nice down there.
gpaddict2 is offline
post #5 of 12 (permalink) Old 11-13-2018, 08:13 AM
Hey...watch this
FZ1guy's Avatar
It sounds like you have the right attitude and are going about getting the bike ready for the track logically. Just don't put too much time, effort, or money into aesthetics. Doing things the 'correct way' has nothing to do with ending up on the ground. You WILL end up on the ground sooner or later.
FZ1guy is offline
post #6 of 12 (permalink) Old 02-26-2019, 02:34 PM Thread Starter
motojay64's Avatar
Garage
Bikes been sitting since its been cold in the garage. Finally, got a great deal on a set of race fairings for the bike so I now have the motivation to start working on it again. Hopefully, if I can keep the garage warm enough I can finish the controls and get the carbs back on.
post #7 of 12 (permalink) Old 03-09-2019, 02:12 PM
Alex_99 is offline
post #8 of 12 (permalink) Old 03-10-2019, 03:48 PM
Lifetime Premium
Sludge's Avatar
Bike: 2002 R6; 2007 R6; 2004 R6
My first track bike was a first gen and I loved it. Rebuilt it from the frame up just like you are and for the same reason; so I knew everything was right. Eliminated the left side switches, bypassed the clutch and sidestand switches, and went very simple with the choke cable. Just cut off the end and use a cable ferrule to make a small loop in the end of the cable. Pull it with your finger to choke it. Not necessarily very aesthetically pleasing, but functional... and track bike, lol.
Also, I hope you marked all of your wiring connectors for reassembly. Otherwise you'll find that most of the 2 wire connectors are identical and can be plugged into multiple locations, only 1 of which is correct. Ask me how I learned that... the wiring schematic will be your friend.
Sludge is offline
post #9 of 12 (permalink) Old 03-24-2019, 09:18 AM
the 2005 r6 was awesome on track. Missing this bike
Cezary Chrobot is offline
post #10 of 12 (permalink) Old 04-26-2019, 09:31 AM Thread Starter
motojay64's Avatar
Garage
So heres the latest update. The bike is DONE and has seen the track for the first time this season!! For having the whole thing ripped apart I must admit it did better than I imagined. I started the day off at 2:11 and ended the day at a 1:59 at NJMP Thunderbolt. First session was wet so I babied it, second session I blew a coolant hose and and third session i blew the fuel pump hose in half. Managed to put a temporary fix on it which ended up starving the pump and only giving enough fuel up to 11,000 RPM. Took it home the same night, made all new hoses and lowered the front triple tree to the 1/2" it was suppose to be at.
FS: 2004 Red/White R6 Track Bike - With Mods - 14K Miles - $3000 - Atlanta, GA dlow Bikes For Sale 2 01-03-2019 06:45 PM
FS: 2007 Blue R6 Track bike - With Mods - 12K Miles - $5000 - Ventura, CA ty1five1 Bikes For Sale 1 09-28-2018 02:16 PM
FS: 2006 White R6 Track Bike - With Mods - 7700 Miles - $4300 - Marietta, GA AgileToad Bikes For Sale 0 08-25-2018 01:23 PM
