The Ray - 2001 R6 Rebuild Log - Yamaha R6 Forum: YZF-R6 Forums
 2Likes
post #1 of 22 (permalink) Old 03-21-2019, 06:35 AM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
Oscar - 2001 R6 Rebuild Log
Hi,
Yesterday I bought a 2001 YZF-R6. It starts and idles, but has bad hesitation and will need some work before being out on the road.
It has:
  • Aftermarket exhaust
  • Dynojet carb kit
  • Rear frame extenders
It needs:
  • New front brake master cylinder reservoir
  • Repaired engine mount
  • Carb work
  • New foot pegs
  • New gas tank
Previous owner said it fell off a trailer.. Hence the damage.
Newbie with a project.
ctag is offline
post #2 of 22 (permalink) Old 03-25-2019, 02:10 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
Re: The Ray - 2001 R6 Rebuild Log
I tried changing the thread title to name the bike Oscar but it either didn't work or hasn't updated.
I took Carb #1 apart and it was really clean and looked properly assembled, so I'm thinking the hesitation may be due to the lack of an air filter and the unconnected vacuum lines off the carb. I'm going to go through and clean and check each of them, then see if just installing them properly fixes the issue.
ctag is offline
post #3 of 22 (permalink) Old 03-25-2019, 08:46 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
The new brake parts arrived today!
The replacement connection kit fit great, but I couldn't get the reservoir mounted in a way that worked well.
ctag is offline
post #4 of 22 (permalink) Old 03-26-2019, 07:38 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
New air filter arrived today.. in an opened package. It has poor fitment and extra mold rubber I had to trim. I think I just got sold an engineering sample.
I took the last three carburetors apart, and accidentally broke one of the coolant couplings. Yikes, they're $50 from bikebandit :-/
I also took the brake caliper off to flush it, but noticed 1) one of the pads is almost spend, and 2) there's mounts for a mirrored caliper and disk on the other side... Do 2001 R6's have dual front brakes? If so, I wonder why mine doesn't.
Man, these brake pads are tiny!
ctag is offline
post #5 of 22 (permalink) Old 03-26-2019, 09:00 PM
oldbonez's Avatar
Bike: '14 R6
Yes, all R6s have dual front brakes. One of the prior owners must have removed. Get a Yamaha or Haynes or Clymer manual, will save you some time and headaches.
Front brake reservoir hose looks long, might be why problematic mounting. Have fun with the build.
Do you have to leave so soon? I was just about to poison the tea.
oldbonez is offline
post #6 of 22 (permalink) Old 03-26-2019, 09:30 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
Thanks oldbonez.
I double checked the manual I found online, and it only shows disassembly for the left side, but does show two hydraulic hoses attached to the master cylinder. I guess I'll keep my eyes open for a right hand side caliper/disk.
ctag is offline
post #7 of 22 (permalink) Old 03-30-2019, 07:27 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
Got the petcock rebuild kit in today and installed it!
ctag is offline
post #8 of 22 (permalink) Old 03-30-2019, 08:12 PM
why do i need 5 post to see pics?
ctag likes this.
jeefongwu is offline
post #9 of 22 (permalink) Old 03-30-2019, 08:14 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
I dunno man. It's like visiting the wise man on the mountain, some things are only apparent after enough engagement with the topic at hand.
We'll get you sorted though. Do you have a bike? How's the weather over there?
ctag is offline
post #10 of 22 (permalink) Old 04-06-2019, 02:39 PM Thread Starter
Fill it with wires!
ctag's Avatar
Garage
Ordered 4 float bowl gaskets, and a replacement coolant joint. $73.
ctag is offline
Back on a R6 (wrecked rebuild) armydog1002 Bike Build Forum 30 05-21-2019 02:16 PM
Back on an R6! Time to rebuild ILoveCarbs New Member Section 0 10-05-2018 11:19 AM
Valve Shims 2001 R6 Anthony Fusco Garage / Mechanical Help 0 07-14-2018 05:17 PM
2001 Yamaha R6 (Blue) // What do ya think ? rhangel New Member Section 25 07-12-2006 06:51 PM
My new 2001 Blue R6 rhangel New Member Section 1 04-07-2004 07:45 AM
