Gen 1 tranny swap ended with NEW motor - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 3 (permalink) Old 06-13-2019, 05:21 PM Thread Starter
Drop a gear and DISAPPEAR
HAndHEldJEsuS's Avatar
Bike: 99 R6
So I found a motor on face book for 200 had harness ecu garage cluster everything. So I drive 4 hours one way to pick it up. It had been sitting for a while. And I seen that water had gotten in cylinder 4 and a little in 3. Made sure it turned over and chanced it and threw it in the back of the truck and on my way back home the whole time thinking somethings got to be wrong internally. Well I get it back and pull the head off and OMG the cylinders are perfect like it’s brand new. So I decided to jus put the gen 2 granny in this motor. Let me say this thing has very low miles!!! I mean it looks like it had been sitting since 99. It still had stock filter on it!! Only thing someone threw a chain but the damage is many bad at all and someone repaired it!!! But I got the tranny in and the case back together and bottom half DONE!!! I’m gonna post pics!! I can’t believe it and it came worth a harness which I was needing!! Also my bike isn’t down while I do he build and I’m going through the WHOLE thing with a fine tooth come and building it better than it is if that’s possible!!! Also a ecu gauge cluster everything bonus!!! So does anyone have a starting circuit relay to sell. It had on I put it on got maybe 100 yards up the street then I dies!!! Thanks and let me know what you think and if I did a good job!!!
ID:	361784   Click image for larger version
ID:	361786   Click image for larger version
ID:	361788   Click image for larger version
ID:	361790   Click image for larger version
ID:	361794   Click image for larger version
ID:	361796   Click image for larger version
ID:	361798   Click image for larger version
RESPECT the machine! If you ever hop on your bike and you are 100% comfortable, SELL IT cause you will end up hurting or killing yourself!!
HAndHEldJEsuS is offline
post #2 of 3 (permalink) Old 06-15-2019, 11:20 AM Thread Starter
Bike: 99 R6
Bottom end done. Now getting into the head which was where the water did the most damage. Gonna have to switch out a few intake valves but alll in all the head is jus like the motor hardly ANY miles!! I never come across deals like this and if I do I don’t have the money so I’m Pumped to get it done and put it in the bike. After that it’s all cosmetic stuff and straightening the abuse the previous dumbass did!! But it’s never really over is it??!?!?
ID:	361828   Click image for larger version
ID:	361830   Click image for larger version
ID:	361832   Click image for larger version
ID:	361834   Click image for larger version
ID:	361838   Click image for larger version
ID:	361840   Click image for larger version
ID:	361842   Click image for larger version
post #3 of 3 (permalink) Old 06-21-2019, 09:23 PM Thread Starter
Bike: 99 R6
Ok so I’m a little late but really don’t matter cause I don’t think anyone is reading but still got the old motor out and all the stuff swapped that I needed. Got it in the bike and fired her up and she purrs like a kitten!!! I’ll post the video of her running later on but here some pics of the old motor out of the bike! Also of the new harness that was a bonus with the motor along with gauage cluster and ecu!!! It’s way more neat and not cut up like my old harness!!!
ID:	361906   Click image for larger version
ID:	361908   Click image for larger version
ID:	361910   Click image for larger version
