Ask MO Anything: Is Clutchless Shifting Bad For My Transmission? - Yamaha R6 Forum: YZF-R6 Forums
post #1 of 4 (permalink) Old 10-03-2017, 09:32 AM Thread Starter
Sponsored Editorial Content
Yes, itís all true. Well, it kind of depends on your bike. Some
with great big flywheels and big gears, like many
and some
Boxers, need the clutch Ė or at least a little clutch Ė for nearly every shift. Most sportbikes only need you to use the clutch to pull away from stops and for the shift from first to second gear.
At slow, around-town speeds, we mostly use at least a little clutch to shift anyway; you donít need to pull the lever all the way in every time you use it. But if youíre steadily accelerating, and especially at WOT (wide open throttle), youíll find that after second gear, if you roll the throttle closed just enough to unload the driveline, for just a split second, with your toe pressing on the lever, then third gear will slip right in without using the clutch at all. Fourth, 5th and 6th will slip in even easier since the gaps between them are increasingly smaller. Done smoothly, itís no harder on your gearbox than using the clutch.
Read more about
at Motorcycle.com.
Motorcycle.com is offline
post #2 of 4 (permalink) Old 10-03-2017, 03:12 PM
R6 is Love. R6 is Life.
Trixim's Avatar
Bike: 2007 R6
Re: Ask MO Anything: Is Clutchless Shifting Bad For My Transmission?
hmm. interesting. still seems controversial. but i can see how on a 599cc block that its nothing to crazy. Maybe on liter bikes it could cause more damage?
Trixim is offline
post #3 of 4 (permalink) Old 10-11-2017, 05:01 PM
well thats big poops
downto is offline
post #4 of 4 (permalink) Old 12-09-2017, 03:11 PM
wouldn't that be a bitch on your transmission for the shift from 1st to 2nd?
Nick Cowley is offline
Clutchless Shifting blavenia Track Tech & Riding Techniques 23 05-22-2014 08:12 PM
clutchless shifting? r6wannaget1 General Discussions 12 05-28-2008 03:30 PM
Clutchless shifting ~03~Raven Track Tech & Riding Techniques 38 09-01-2007 01:14 AM
ClutchLESS Shifting benny General Discussions 22 03-06-2007 11:38 AM
clutchless shifting deltaonex General Discussions 3 05-16-2004 09:00 AM
HTML code is On
